Need help finding DVR to use with cable - AVS Forum | Home Theater Discussions And Reviews
Old 12-02-2011, 08:05 AM - Thread Starter
lincoln antenna's Avatar
First, I am not sure if this is the right forum. Please let me know if I should post somewhere else.
Here are the facts:
I have Time Warner Cable.
I am adding a 2nd tv. (First tv I rent the HD DVR cable box from TW)
For the 2nd tv I want a basic DVR unit that I can buy and plug in the TW cable card.
I don't want to have to pay for any monthly subscription.
I don't want to have to use my PC as part of the set up.
What are my best options?
Thanks in advance.
lincoln antenna is offline
Old 12-22-2011, 07:00 PM
Waseem's Avatar
Hi lincoln antenna
What I would suggest is the Magnavox RMDR515H/F7. This is a DVR with a DVD burner and a 500GB hard drive built in. It has a nice digital tuner that can pick up most of the digital cable signals, I am not sure about Time Warner, and has some added features that you can check at:
http://www.magnavox.com/p/index_player.php?id=60
I hope you can buy a refurbished unit from Amazon (http://www.amazon.com/Magnavox-MDR51...4605296&sr=8-3) and save some on a great unit.
I own one and I have not had any glitches and I am hoping not to. Also in this forum there is mention of having the HDD and the DVD burner as easy to replace parts if anything should go wrong.
Hope I wetted your appetite ;-)
Waseem
Waseem is offline
Old 12-22-2011, 07:18 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Click $1 in my sig. for an indexed list of info and help files on the Mag HDD/DVD recorders.
wajo is offline
Old 12-26-2011, 01:37 AM
Tulpa's Avatar
Liked: 61
The only thing I can think of that satisfies both would be a Moxi or a TiVo with lifetime. You could probably find used versions of both on eBay.
New, they'd cost $500 or so.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
