Avermedia Game Capture HD - AVS Forum | Home Theater Discussions And Reviews
Old 02-29-2012, 03:01 AM - Thread Starter
kurosaki23's Avatar
hye, im newbie here...im a Malaysian
i wanna record from my set top box using the avermedia game capture hd..
the problem is, i have to convert hd to component since the game capture only got component input and out put..what converter did u recommend...after that..i have to find another converter to convert component to hdmi..to go out to my hdtv..
any suggestion?
kurosaki23 is offline
Old 03-30-2012, 12:27 AM
person12's Avatar
So you're coming out of the set top box as component. Well it depends on quality, there are many adapters that can go from component HD to HDMI.
person12 is offline
