Buying a used SA 8300HDC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-17-2012, 09:23 AM - Thread Starter
setchell's Avatar
Hi, Sorry if a repeat but if I buy a Scientific Atlanta 8300HDC that was used in Columbus Ohio (cable provider not known) will it work here in Ocala FL with Brighthouse?
They use these here but I can't get one at this time. The last one I had was better than the newer Samsung models here.
setchell is offline
post #2 of 4 Old 06-19-2012, 05:51 PM
Speedskater's Avatar
Quoted: 20 Post(s)
No major US cable company will activate any 8300HDC that they did not provide to their customer.
Kevin
Speedskater is offline
post #3 of 4 Old 06-20-2012, 07:42 AM - Thread Starter
setchell's Avatar
Ok, thanks for the info. I talked to the cable guy here and he said about the same thing.
setchell is offline
post #4 of 4 Old 06-20-2012, 06:57 PM
mhufnagel's Avatar
Quoted: 22 Post(s)
Liked: 92
As a matter of fact it's most likely stolen.
mhufnagel is offline
Reply Digital Recorders (PVRs) General
