Motorola DCH 3416 Dolby Digital Setting - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2012, 05:52 PM - Thread Starter
Carmine782's Avatar
Hi, I have a Sony Receiver with HDMI to my TV (along with my blu ray and PS3) and output all to my TV. My PS3 and Blu ray all have Dolby digital audio. My TV did as well, but i had to switch cable boxes with Comcast. Does anyone know the setting on the Motorola DCH 3416 to enable Dolby Digital through HDMI. Once again, I just switched cable boxes, so i know all my other settings are correct and cabling is correct. Everything was working fine before i switched cable boxes
Write back
Carmine
Carmine782 is offline
Old 06-18-2012, 06:35 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
This works in Richmond, VA - Comcast,
1) Turn on TV & box, verify you are on the correct input.
2) Turn off cable box only.
3) Point Comcast remote @ box and tap "Menu" (make sure remote is in cable mode)
4) Setup menu should appear on your screen, navigate down to audio adjustment and try a different setting (I'm not looking at one now so I don't remember what the choices are). You may need to go into a sub menu entitled "Additional HDMI settings". You can't brick the thing by changing any settings in there so feel free to experiment,
5) Turn off box, then turn back on
Dropkick Murphy is offline
