Can't get IR blaster from my Sony DVD recorder to work on the Comcast box. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-03-2012, 11:51 AM - Thread Starter
tosborn's Avatar
I recently moved and am being forced to use Comcast in the apartments. They issued me a DCI1011COM box. I've tried setting up the Sony DVD player to change channels on the Comcast box using the IR blaster, but none of the codes they have programmed in are working. The Sony DVD player doesn't allow you to manually enter a code, you have to select brands and go through the pre-programmed codes. I've read online that people have gotten an IR blaster to work on this particular Comcast box with a five digit code that ends in a number, but nothing like that is available in the Sony DVD player - it only uses 1, 2, or 3 digit codes. Does anyone have any advice please? smile.gif
tosborn is offline
Reply Digital Recorders (PVRs) General
