Best DVR for Over-the-Air recording - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 04-14-2015, 04:09 PM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
Glad you're happy. A lot of people like the whole house DVRs. If you came to me saying you had a house full of Rokus, I would certainly recommend you start with a whole house DVR. Even if you decided to go with a set top DVR, the other would be good for other devices. The Simple DVR is particularly good for remote access.
Still, for someone looking to cut their cable, who has no existing infrastructure, I am always going to recommend running a coax from an attic or roof antenna to a DVR+. For most people, this is very close to the cable experience and a very good price.
wizwor is offline
Old 05-13-2015, 11:16 AM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
Have spent the last week playing with a TiVo Toamio OTA. Bought two @ $299.99 with Lifetime and wish I had bought three. You do need to have internet or dialtone with the TiVos, but there are no monthly fees and $299.99 is competitive with the Channel Master DVR+. I would advise everyone to keep an eye open for an encore of this deal.
wizwor is offline
Old 07-06-2015, 11:54 PM
jaxstraww's Avatar
Quoted: 12 Post(s)
Your big on the Channelmaster DVR+ solution.
I have the Fios local channel package. Not using OTA for my main TV that needs a DVR. TV is a newer Sharp with QAM so I just pipe the coax cable into the TV and get my main locals which is what the wife wants. We supplement other TV using Netflix & a Hulu+ solution. Streaming box is a Nvidia Shield.
Would this Channelmaster work with a QAM setup as I explained? I'd like to pipe the coax with my Fios local package into the DVR and then run the DVR into the TV using HDMI. For internet connectivity I would use a wireless thumb drive I have laying around. No access to an Ethernet connection for Internet.
jaxstraww is offline
Old 07-07-2015, 12:26 AM
jaxstraww's Avatar
Quoted: 12 Post(s)
Well, after some reading the channelmaster won't work. After reading some Amazon questions it looks like only an OTA feed will work. No QAM tuner built in.
Do you have any recommendations for a similar DVR device that I can use QAM on? OTA antenna is not an option for this TV.
Old 07-07-2015, 05:02 AM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
When you say an antenna is not an option for 'this tv', are you saying there is no OTA at the set or at the location (address)? The only QAM DVR I have experience with is the Simple DVR. These are no longer generally available and require a software license.
Take a look at this...
http://www.amazon.com/3500STBII-Mult.../dp/B00GOILYB6
wizwor is offline
Old 07-07-2015, 03:29 PM
lrhyne11's Avatar
Help - "VCR" type recorder needed
Okay, if I'm in the wrong forum, feel free to redirect me. I have cut the cord, but have a question. I have two HD TVs and two Rokus (subscribe to Netflix and Sling TV for most of the year). I am lucky and can pick up a decent # of OTA local & PBS stations with $10 indoor antennas. Occasionally, there are two OTA network shows on at the same time that I wish to watch. Since my circa 1990's VCR no longer works, what is the least expensive way to be able to record one show on just one TV. I don't need to be able to skip commercials or anything like that. It would be nice to be able to set ahead of time (i.e. set to record every Thur @ 10pm on channel 9.1) I don't wish to pay a monthly fee since I will only use this 15 - 20 times a year for an hour or so each time. Most of the DVRs I've looked into seem to be overkill for my needs.
Thanks for any help!
lrhyne11 is offline
Old 08-16-2015, 04:12 PM
avshelden's Avatar
Okay, if I'm in the wrong forum, feel free to redirect me. I have cut the cord, but have a question. ... Since my circa 1990's VCR no longer works, what is the least expensive way to be able to record one show on just one TV. [...] Most of the DVRs I've looked into seem to be overkill for my needs.
While I'm know there are many users whose experience was not what mine was and would not make this recommendation, I would recommend you try to find a DTVPal converter box (TR40). There is a lengthy forum here: Dish DTVPal / Echostar TR40 digital to analog converter
This should work with your VCR and allow you to program both to do the recordings. We did this for quite a while but ultimately decided we wanted a real HD DVR and bought the DTVPal+ DVR/Channel Master 7000 (I think) which is no longer sold. We have been extremely happy with ours although we do still deal with issues when we go through daylight savings time changes. (forum here: The Official AVS Dish DTVPal DVR Topic!)
I saw a couple of the DVR models available on ebay today and would highly recommend that route as a low cost (but not bulletproof) solution.
avshelden is offline
Old 08-16-2015, 05:00 PM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
The DTVPal has not been manufactured for a half dozen years. I happen to own three and love them, but cannot recommend one now due to the age of the hardware.
Right now, I would recommend the TiVo Roamio/OTA at $300. It is the best DVR at any price and at $300 it is very reasonabley priced.
wizwor is offline
Old 08-20-2015, 03:58 PM
rsamos's Avatar
Just last week I hapened to stumble onto a link to the $300/lifetime deal on an OTA that wizwor mentioned above and couldn't pass that up. I also picked up a Mini to go with it.
I've put in the needed hardwired network connections for the Mini, and this weekend will be moving the antenna that's sitting on a floor pointing out a window up to the roof. After that, I should be ready to deal with the Dish Customer Retention Specialist and cut the cord.
This is my first experience with Tivo. While the interface is admitedly a bit clunky, it's not at all a deal breaker for me. In every possible way this DVR is signifcantly better than the Dish DVR (Hughes?) I've been using for years.
One thing I've been wondering is if Tivo ever updates their streaming apps. I was hoping that maybe by winter the HBO Now app would show up.
rsamos is offline
Old 08-20-2015, 04:16 PM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
They do.
wizwor is offline
Old 08-20-2015, 04:22 PM
rsamos's Avatar
Originally Posted by wizwor View Post
They do.
xlnt.
rsamos is offline
Old 04-15-2016, 08:49 AM
isamu's Avatar
Quoted: 34 Post(s)
Hello. I too am in the same boast as the OP. I talked to someone here in LA that is willing to hook up a OTA installation for me for fairly decent price.
My main concern is record and playback performance. I used to watch OTA and had a Conaxsat Trio many years ago(2008) and its performance was terrible! Video would always stutter and freeze. Do these newer boxes suffer from these issues? Which box excels in the areas of performance in your opinion?
isamu is offline
Old 04-15-2016, 10:35 AM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
As far as I know, all the modern DVRs are excellent recorders. They distinguish themselves on features and price.
https://freetvforme.wordpress.com/20...vrs-announced/
https://freetvforme.wordpress.com/20...el-master-dvr/
https://freetvforme.wordpress.com/20...asics-in-2015/
I don't have any hands on experience with the new Magnavox DVRs, but they sound like a nice alternative to TiVo and DVR+. I have both TiVo Roamio/OTAs and Channel Master DVR+s. Both work great and make excellent recordings.
TiVo just released a new Bolt DVR which is OTA and cable. It's probably a great DVR, but VERY expensive with monthly fees or a $600 once time fee (on top of purchase price). After using a TiVo for nearly a year, I am using a DVR+ again (wife prefers the TiVo). TiVo has apps for top services, DVR+ has free linear streaming apps, and Magnavox has no apps at all.
wizwor is offline
Old 04-15-2016, 04:03 PM
isamu's Avatar
Quoted: 34 Post(s)
Thank you very much for your reply. May be a dumb question, but what exactly is the difference between a PVR and a DVR? Can a PVR box, assuming there's a seperate USB Hard Drive attached, function the same way a box with a built in DVR can? Can I rewind, pause, etc with the PVR box?
isamu is offline
Old 04-15-2016, 05:31 PM
wizwor's Avatar
Quoted: 259 Post(s)
Liked: 159
Digital Video Recorder vs Personal Video Recorder? No idea. I would suggest you pay more attention to features and price than to name. If you have some specific devices in mind, it might make more sense to compare them.
wizwor is offline
Old 04-17-2016, 09:20 AM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
They appear to be different terms to mean the same thing.
E.g., https://en.wikipedia.org/wiki/Digital_video_recorder opens with this statement:
A digital video recorder (DVR), sometimes referred to by the merchandising term personal video recorder (PVR), is a consumer electronics device or application software that records video in a digital format ...
http://whatis.techtarget.com/definit...o-recorder-PVR
A personal video recorder (PVR) is an interactive TV recording device, in essence a sophisticated set-top box with recording capability (although it is not necessarily kept on top of the television set). Vendors and media also refer to the units by these names: digital video recorder (DVR); personal TV receiver (PTR); personal video station (PVS); and hard disk recorder (HDR).
http://www.webopedia.com/TERM/P/PVR.html
A PVR is also referred to as a hard disk recorder (HDR), digital video recorder (DVR), personal video station (PVS) , or a personal TV receiver (PTR).
http://www.differencebetween.net/obj...n-pvr-and-dvr/
3. Both are basically referring to the same product
This last link above actually tries to draw a distinction between the two by mentioning that "PVR" means that one can "personalize" whereas "DVR" emphasizes "digital", but the two terms have grown to mean the same thing and one has to look at the feature set of any prospective device, not whether it was labeled PVR or DVR. And, according to the same article, the term "PVR" is "largely obsolete".
My very humble setup:
Spoiler!
Mark12547 is offline
Old 01-12-2017, 04:38 AM
Liked: 0
Originally Posted by Haywood Jablomi View Post
I have a quad tuner Tablo with a 1.5TB hard drive feeding four televisions via Roku. I do not include the cost of the Roku boxes, because I already had them for use with Netflix, Hulu, Amazon, Plex, Vudu, Spotify, Pandora and other stuff. The Tablo, antenna, hard drive and lifetime subscription was $600. A single quad tuner box is plenty enough for my family of four and I am about to experiment with sharing it with my parents who live too far out for OTA, but have good internet service. We rarely watch live TV and we spend a lot of our TV time viewing other content, so the DVR almost never has more than one user at a time. Because we are such light users, the Tablo was a really good value proposition and it gives us access to our programming literally anywhere without having to transcode stuff and move it to my NAS. Tablo is also supposed to be working on NAS storage support, which will make things even better. The software has steadily improved over time. The stability is fantastic and the box does not overheat. I couldn't be happier.
Been a happy Tablo user also, great little boxes. I've been using the dual tuner model since they first released them.
Very wife friendly also
white_noise is offline
Old 01-13-2017, 02:07 PM
DavidinCT's Avatar
Quoted: 243 Post(s)
Liked: 67
You could always use a old Windows 7 PC and add a tuner or 2 to use Windows Media Center. If tweaked right, they do make a great DVR.
1. An old PC (as long as designed for Windows 7), a tuner (or 4), and a WMC remote kit (under$25 on ebay)
2. Free Guide data
3. HDMI, Component, S-VIDEO, or even composite video is possable depening on the video card you have.
4. Supports OTA, cablecard or other formats (depending on tuner)
5. More than 4 tuners is possable (registry hacks will alow 30+ tuners if NEEDED/WANTED)
6 Custom guide data and tuner managment, use one Attenna for a few channels, use another one for other channels and combine them in 1 guide.
7. DVR storage is up to how much space you want to add
8. Interface has options for FM radio, Movie Libray and even 3rd party addons to put like youtube and other things.
9. A internet connection IS required for guide data.
WIndows Media Center was designed for single core/dual core CPUS (Windows 7 release), so it does not need a high end PC to run.
If you wanted to TWEAK your setup for what channels you get, Windows Media Center with a good tuner can be a very powerfull system.
It would be a PC so there is always little things to them but, a good solid system backup and disable all updates....stays working rock solid.
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
