Convert DVD Recorder to record from digital LCD television - AVS Forum | Home Theater Discussions And Reviews
Old 07-06-2013, 06:58 PM - Thread Starter
Tippo42's Avatar
Gday all
I have a Panasonic DVD recorder (DMR-EH65) which must be 5 years old but has had little use. It would have an analogue tuner. Is there any way to convert this for use with a new flatscreen digital television. I assume that the dvd recorder would need a digital tuner ( or something).
Any ideas as to how this might be achieved before we convert fully to digital television and analogue television is switched off in Australia.... or should I just scrap the DVD recorder?
Tippo42 is offline
Old 07-07-2013, 02:13 PM
greaser's Avatar
Quoted: 100 Post(s)
Liked: 61
Tippo you'll get a much faster answer to your question if you repost it in the DVD Recorder forum.They'll be glad to help you there.smile.gif
greaser is offline
Old 07-07-2013, 06:03 PM - Thread Starter
Tippo42's Avatar
Thanks greaser!
I assume that you meant DVD Recorder (Standard Def) so I have reposted my query there.
Tippo42 is offline
