DVD BURN WITH PVR PROBLEM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-04-2014, 11:57 AM - Thread Starter
mou353's Avatar
I bought a Hauppague PVR 2 1512.  It is hooked up to my STB with component. The original file captured is fine.  I captured it in TS and it is 1920x1080. From there I edited out commercials using the Arcsoft software included.   After I cut the commercials I burned it to a DVD using Arcsoft.  The hi def stayed but the first 5 to 10 seconds of the show right after the cut were out of synch.  It corrected itself after that until the next cut.  I tried burning on other software but they wouldn't burn it in 1080.  They switched it to 720 standard def.  Any suggestions what I can do?
mou353 is offline
Reply Digital Recorders (PVRs) General
