DVD Recorder connection to Direct TV DVR - help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-21-2014, 12:22 PM - Thread Starter
ArielSue's Avatar
I am so confused attempting make the connections I need.  I have Direct TV, with a DVR, I recently purchased a Toshiba - DVD RECORDER & VHS RECORDER (DVR620KU)".   I am trying to figure out how to connect my Toshiba DVD/VHS Recorderthrough my DirecTv DVR, so I can record TV programming and so I can record the programs on DVR onto my Toshiba DVD/VHS Recorder.   Can ANYONE PLEASE tell me the steps I need to take to accomplish this?  PLEASE!  Thanks!
ArielSue is offline
post #2 of 7 Old 04-21-2014, 02:08 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
Have you looked at the manual? There are pictures that show you how to connect everything starting on page 19.
http://support.toshiba.com/support/staticContentDetail?contentId=2842852&isFromTOCLink=false
Your DirecTV is essentially your external tuner in that drawing on page 19.
The DVR620 only accepts Svideo or composite video inputs (ie. standard definition low quality). So you need to connect the red/white analog audio outputs of the DirecTV receiver to the L/R Audio inputs on the DVR620. Then you need to connect either the Svideo or composite (yellow) video out from the DirecTv to the input on the DVR620. Then when you are watching something on the DirecTv box you just hit record on the DVR620.
If possible I would also run the HDMI from your DirecTv to your TV directly so you don't end up having to go through the DVR620 and can take advantage of the better quality output of your DirecTv receiver (I'm making an assumption that your TV and DirecTv box are both HD.
Does that help you?
walterappleby is offline
post #3 of 7 Old 04-21-2014, 11:33 PM
Church AV Guy's Avatar
Quoted: 102 Post(s)
Liked: 81
I second what walterappleby said. Hook the satellite dish to the DirecTV DVR, hook the DVR to your television using HDMI, hook the DVR to your DVD recorder using L/R/video (S-Video or composite) and hook the DVD recorder to the television using the best connection you have left. That's the way I have it and it works great. You can watch the DVR without going through the DVD recorder if you want.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #4 of 7 Old 04-21-2014, 11:47 PM
VisionOn's Avatar
Liked: 1453
You should check this forum: http://www.avsforum.com/f/106/dvd-recorders-standard-def
That area of the site is where DVD recorder experts reside.
VisionOn is online now
post #5 of 7 Old 04-23-2014, 06:47 PM - Thread Starter
ArielSue's Avatar
Hi Walter,  Yes, your information is very helpful.  I do have the manual, but didn't see where it discussed how to connect it to the DVR, maybe I missed it, I will look at it again.  Additionally, your other information is very helpful, as I had no idea what type of wiring went into what component or in what order they needed to be connected.  I REALLY APPRECIATE your response, truly.  I will follow your information and get it done tomorrow.  Thank You So VERY Much, ArielSue
ArielSue is offline
post #6 of 7 Old 04-23-2014, 06:49 PM - Thread Starter
ArielSue's Avatar
Thank You So Very Much
ArielSue is offline
post #7 of 7 Old 04-23-2014, 06:51 PM - Thread Starter
ArielSue's Avatar
ArielSue is offline
Reply Digital Recorders (PVRs) General
