Mixing Variable Bit Rate and Constant Bit Rate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-11-2015, 04:30 PM - Thread Starter
Tomar's Avatar
Quoted: 12 Post(s)
Hello
I am using eyetv software to record TV shows of my satellite STB. I'm pretty sure the shows are transmitted using variable bit rate. There is an option in the eyetv software to choose either variable bit rate or constant bit rate for recording. Which is the correct setting, VBR or CBR? Should I match the bit rate setting when recording? Also which is best for transcoding?
Tomar is offline
Reply Digital Recorders (PVRs) General
