I have a Sony KV36XBR450 Tv with DRC. Have just received a ReplayTv 5040. (5040 has latest V5 software) I have the 5040 connected to the tv using the component (Progressive scan) out on the 5040 & component in on the tv. (Y,P/b,P/r) (Progressive scan). I have also selected the Y,P/b,P/r out mode during the setup of the 5040.
This setup DOES NOT enable the DRC mode on the Sony Video menu. I have two (2) other devices that have component/Progressive scan / Y,P/b,P/r outputs. Both of these components enable the DRC mode on the Sony tv. I have used the cables from the other components to connect the ReplayTv to the Sony. No joy! Does anyone have a similar setup that can tell me if my replayTv 5040 is defective. Have talked to the Replay tech's and while are very helpful, they can't answer this question. help!
My picture is very good, but if the DRC mode is active, it is better. Those of you with Sony/DRC know what I am saying. Thanks CB
