Increasing Capacity of Cable PVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-16-2003, 08:43 AM - Thread Starter
neo1's Avatar
Is there any way to expand the capacity of a cable PVR by adding an external hard drive?
Thanks much.
neo1 is offline
post #2 of 6 Old 08-03-2003, 08:03 AM
Shelbrain's Avatar
I haven't found a way around this so far. I know Brighthouse has another box with twice as much space for an additional fee. Seeing as how my cable/internet is already $130+/month, I couldn't get the girlfriend to split it with me.
Shelbrain is offline
post #3 of 6 Old 08-05-2003, 06:52 AM
Dannytheman's Avatar
Not in the SA and Motorola World as it is now. How much space are you loking for? isn't 80 gigs enough?
Dannytheman is offline
post #4 of 6 Old 08-05-2003, 07:13 AM
dt_dc's Avatar
Unfortunately, with the SARA software, you can't use the full 80 gigs due to a lack of disk space management (prioritize things for automatic deletion as space is needed, etc.).
dt_dc is offline
post #5 of 6 Old 09-01-2003, 08:12 PM
AnthonyNYC's Avatar
Do you mean the SA8000 has an 80g inside?
Also what would happen if you swapped a bigger HD inside?
Would it load the appropriate software automatically like the Dish player does or would it need some sort of transfer software like the Replay and tivo's do?
I would guess since its hooked up directly to high speed cable, it would do it automatically like a dishplayer PVR.
I remember just swapping the 15 gig with a 40gig years ago on my first PVR the dishplayer and how happy I was when it worked after downloading and setting up in a few minutes.
I am tempted to try this with my cable PVR but if someone already has and had no luck, then I will save the effort.
Has someone already tried?
TIA,
AnthonyNYC
AnthonyNYC is offline
post #6 of 6 Old 09-08-2003, 12:33 AM
rubaiyat's Avatar
I just asked Comcast for a second SA8000, and they provided it to me, for an additional $4.95/month. This lets me relax and spend as much time as I need to transfer the shows on my full first model to DVD-R: Authoring DVD. This is another way to "increase the capacity of Cable PVR".
rubaiyat is offline
Closed Thread Digital Recorders (PVRs) General
