Downloading from SA8000 ? - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2003, 12:45 AM - Thread Starter
ktb
ktb's Avatar
Has anyone got any pointers for pulling shows off the SA8000?
I've managed to fill mine to capacity, and wanted to find a more elegant (and less tedious!) solution to saving the shows to my HD than hooking up a Replay and re-recording all the shows.
I'm not opposed to popping the puppy open to get at it's HD, but I've no idea what filesystem PowerTV uses, etc.
TIA!
ktb is offline
Old 09-01-2003, 09:02 PM
AnthonyNYC's Avatar
Can you let me know what its limit is? 30 hours?
Also, I don't know about getting shows off it, I assume the 1394 ports aren't activated in software yet, but do you think popping it open and adding a bigger hard drive, like a 120g would work?
I would think it should format and load OS automatically on the first reboot like when it was first activated, but am not sure.
Anyone try this yet?
AnthonyNYC
AnthonyNYC is offline
Old 09-21-2003, 02:57 PM
rubaiyat's Avatar
Wow I am also interested in this precise problem. I got two SA8000s from Comcast, the second came after my first (80GB) was filled. Has anyone tried to use the USB? port in the front of the box? I'm afraid to pop the top but if the second box fills up and I have to beg Comcast for a third, I just might pop it!
rubaiyat is offline
Old 10-09-2003, 07:01 PM
goony's Avatar
Try asking / looking in this Yahoo! group: http://groups.yahoo.com/group/explorer_8000/
goony is offline
Old 10-10-2003, 04:52 PM
rubaiyat's Avatar
Thanks goony, I will sign up for this website!
rubaiyat is offline
Old 10-15-2003, 04:51 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
I recently ran out of recording space on mine so i counted up all my hours and i had 16 hours of digital and 14 hours of analog programming packed onto the thing. So yeah, 30 hours it is :-)
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
