SA8000 HD question - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2003, 12:46 PM - Thread Starter
superbigg's Avatar
Is the SA8000 "HD" the only way to record or can you still use the SA8000 + a top box for HDTV?
thx
Super
superbigg is offline
Old 11-02-2003, 05:45 PM
ServerKing's Avatar
No you will need an HDTV box the SA8000 doesnt have HDTV build into it.
ServerKing is offline
Old 11-13-2003, 08:45 PM
vegggas's Avatar
The SA 8000HD is an HD PVR. It was created 4th qtr of 2002, over a year ago. Unfortunately it has not been released, just like all the other HD PVR's, until the legal issues are sorted out. The SD version is currently available in many markets, and the HD version should legally be available in Jan or Feb of 2004.
vegggas
vegggas is offline
Old 12-05-2003, 12:27 PM
gmclaughlin's Avatar
To answer the question you asked, yes, you can use an SA 8000 and a HD Set top on the same tv. Just connect the 8000 to the svideo/composite/or RF input, and the HD set top (3100HD likely) to the component inputs. Then just switch inputs to view the desired box.
Because both boxes use the same remote codes, a press of a the remote will send the same signal to both boxes, which isn't a big deal unless you're ordering iControl or a PPV movie, and then you might accidentally buy two copies! Just turn one box off before doing so. (You can always call customer service and ask for a credit if you get double billed).
Hope this helps.
Greg
gmclaughlin is offline
Old 12-05-2003, 01:27 PM
rgrossman's Avatar
I keep one box powered on and the other off, so when I hit the power button on the remote the one I'm not using is always off.
Rich
rgrossman is offline
