Unlocking TIVO's 30 second skip - AVS Forum
post #1 of 8 Old 12-07-2003, 08:20 AM - Thread Starter
thegratingone's Avatar
I have read that there is a way to get TIVO to do a 30 second skip like Replay does. Anyone heard of it? Thanks.
thegratingone is offline
post #2 of 8 Old 12-07-2003, 08:23 PM
jager24's Avatar
While you are playing back a recording, enter the following:
Select-Play-Select-3-0-Select...
jager24 is offline
post #3 of 8 Old 12-08-2003, 05:49 AM - Thread Starter
Thanks, but the big trick is hitting 6 keys vs. the Replay one??? I thought there was something to "unlock" a special key or something like that. Oh well, thanks again.
post #4 of 8 Old 12-08-2003, 09:22 AM
thatguy79's Avatar
if you enter those six keys, it turns the "Skip To End" key on the remote to a 30-second skip key. so from that point on, just press that one button and it will skip 30 seconds.
thatguy79 is offline
post #5 of 8 Old 12-08-2003, 09:24 AM - Thread Starter
post #6 of 8 Old 12-14-2003, 01:08 PM
HD_JUNKIE's Avatar
Works on my Samsung DirecTivo too. Thanks.
BTW, how do you switch the skip to end button back?
HD_JUNKIE is offline
post #7 of 8 Old 12-25-2003, 11:59 AM
yesno's Avatar
Repeat the S-P-S-3-0-S or reboot.
yesno is offline
post #8 of 8 Old 01-22-2004, 10:57 AM
jlb
jlb's Avatar
Just to further what yesno said.....after you "enable" 30-sec skip on a TiVO, if you have any sort of a reboot (i.e., if the power goes out), you will have to re-enable the function. And for me it is a "one button" press as I have a hidden button on my Pronto that does it all for me......
jlb is offline
Closed Thread Digital Recorders (PVRs) General
User Tag List
