Explorer 8000 Series Recording bug? - AVS Forum
post #1 of 6 Old 02-01-2004, 08:30 AM - Thread Starter
jdifonzo's Avatar
It seems to go like this:
Series Record show A (which runs from 8:30 to 9:00 on channel X).
Series Record show B (which runs from 9:00 to 9:30 on channel X).
Series Record show C (which runs from 9:00 to 10:00 on channel Y).
This should all work fine. Then go in and change show A's recording preferences to record 2 min early & 2 min late (because the network never seems to be on time with the local cable co). No warning is given, even though this would seem problematic because there are only 2 tuners.
Result:
Show A records from 8:28 to 9:00.
Show B records from 9:00 to 9:01. (!!!)
Show C records from 9:00 to 10:00.
And there seems to be no warning at all that this is going to happen. Change show A's settings to start & end on time and all is well (except for the network time sync problem).
Since they move the shows around time slots now and then, it seems like using the before & after recording extensions is a dangerous thing. You never know when it's going to mess you up.
Anyone else see this behavior?
jdifonzo is offline
post #2 of 6 Old 02-01-2004, 02:13 PM
MethodMachine's Avatar
Welcome to the brave new world of the networks f%$!ing around with the schedule to mess with the general public. AFAIK, this confounds everyone using a PVR. The only recourse is to write naster letters to the offending stations and consider purchasing multiple PVRs to resolve conflicts.
If Necessity is the mother of invention, then Laziness is surely the father.
5040(1): 00004-54831-55585
5040(2): 00004-54831-83297
MethodMachine is offline
post #3 of 6 Old 02-16-2004, 04:25 PM
lbecque's Avatar
Haven't noticed that one yet but I have documented MANY, MANY other bugs in the software for the SA 8000. And I have only used it for 1 week!
The worst is it automatically deleted 10 recordings on me that were specifically marked to be saved until I manually deleted them.
lbecque is offline
post #4 of 6 Old 03-03-2004, 05:28 PM
jetblac's Avatar
I tell you what would be nice. A complete delete option. so I don't have to delete 30 shows one by one. Other than that, I haven't seen any glitches. Staten Island NY
jetblac is offline
post #5 of 6 Old 03-04-2004, 08:10 AM
dt_dc's Avatar
With SARA:
To erase all saved recordings.
WARNING! This will erase all saved recordings and may not be authorized by Scientific Atlanta. This may damage your box and/or void your warranty. I make no guarantees on the safety of this procedure.
Turn the box off.
Press and hold the PAUSE key on the remote until the Mail light starts
blinking - 10+ seconds
Press Page Down on the remote.
Press LIST.
Press LIST.
Press LIST.
Wait as the box reboots.
I've done the above and it works like a charm.
dt_dc is offline
post #6 of 6 Old 03-04-2004, 08:44 AM
jetblac's Avatar
Thank alot
jetblac is offline
Closed Thread Digital Recorders (PVRs) General
User Tag List
