Are terapin recorders discussed in here? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-19-2004, 10:21 AM - Thread Starter
Papaman's Avatar
If so.. I have the option to buy on cheap from a friend but the cdrom door wont coem out when the eject button is pressed. Otherwise it works fine.
Can any cdrom burner be used in these or does it require a certain model?
I want sure if the bios checks the model & make on the cdrom.
Papaman
Papaman is offline
post #2 of 2 Old 03-22-2004, 06:23 PM
Chris Gerhard's Avatar
This forum is for PVRs only, digital hard disk video recorders not covered in other sections of AVSforums. I don't think there is a section for that device, you might ask in the DVD recorders section since it is closer to one of those than one of these.
Chris
Chris Gerhard is offline
Closed Thread Digital Recorders (PVRs) General
