PC Based PVR no good with Satallite? - AVS Forum | Home Theater Discussions And Reviews
Old 03-19-2004, 12:31 PM - Thread Starter
SabreOfSD's Avatar
Quoted: 16 Post(s)
Hello all,
I have been thinking about building my own PVR for some time now, but just recently realized something. I will be moving in the next month or so and getting DirecTV. Am I wrong in that my PVR will then become useless since it can't change channels and such (aka, DirecTV's box has to do it)? Basically PVR's (unless you get the ones direct from the companies like Comcast or DirecTV) will not work with anything but analog cable... Is that a correct assumption?
TIA!
Julian
Sabre
SabreOfSD is offline
Old 03-19-2004, 03:50 PM
xski's Avatar
Its possible but cumbersome.
You have to add an IR transmitter to your homebrew pvr so it can pretend to be a remote and tell the other tuning devices (sat reciever, cable box, VCR, etc) to change channels (or other settings).
Of course, this assumes the other tuning devices can be controlled via IR.
-xski
xski is offline
Old 03-19-2004, 10:36 PM
elm_sd's Avatar
There is a pc based pvr made by tapeitall that can do all you ask, even change Sats on a C band system.
ELM_SD
Quality TV = C-Band
elm_sd is offline
Old 03-23-2004, 09:36 AM - Thread Starter
SabreOfSD's Avatar
Quoted: 16 Post(s)
Thanks for the info! I'lll be looking into the IR changer and let you know how it goes :)
Sabre
