PVR Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-26-2004, 08:53 AM - Thread Starter
rholland65's Avatar
For a homemade PVR, what settings are people using?
Things like codec, resolution, CBR/VBR rates and other settings make for a lot of options.
There is a trade off between quality, size and realtime encoding ability. For a good quality DV transfer, it takes much longer to encode than 29 frames per second. That realtime encoding requirement for PVR makes the settings much more critical.
I'm using a Samsung 50" DLP for the display, so it has to look good when big.
rholland65 is offline
Closed Thread Digital Recorders (PVRs) General
