SA 8000hd NO PASS THRU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-15-2004, 05:19 PM - Thread Starter
fastlane2546's Avatar
I have the SA8000 HD for a few weeks and I have been told DVI will not be active untill Sept. but with my SA 3250HD when I didn't use the DVI and I used the component connection I had a choice of Pass Thru or Fixed and 2 Up converts, with the SA 8000HD there is no choice I have to change it manually with each station in the settings menu to 1080i or 720p or 480p something does not seem right I should not have to switch manually with a box that was made 1 or 2 years after the Sa3250HD. What am I doing wrong.
fastlane2546 is offline
post #2 of 2 Old 06-15-2004, 05:28 PM
bfdtv's Avatar
You're doing nothing wrong. The SA8000HD does not have pass-through. Indeed, there are no dual-tuner HD DVRs available anywhere with pass-through.
Pass-through capability may or may not be added with DVI support in the SR1.2/SR1.3 release coming ~September.
bfdtv is offline
Closed Thread Digital Recorders (PVRs) General
