SA8000 and Comcast (MA) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-23-2004, 11:03 PM - Thread Starter
jpaq's Avatar
I'm thinking of getting an SA8000 unit for use in my home, but judging by the costs of monthy rental vs. buying a box on E-bay, it really seems like my best bet is to buy the box rather than renting it from Comcast.
I have a few questions though.
1) Does Comcast have to be giving out SA8000 boxes for this to work? If they are going to go with Motorola boxes here, is my SA8000 going to work?
2) Comcast says here that DVRs are currently "in testing" and should be available "by the middle of the summer". Do DVRs have to actually be supported before I can use an SA8000 if I purchased it from E-bay.
3) Is there any other charge from Comcast for service fees beyond the increased box rental cost that would be associated with being able to use my DVR?
If anyone has any other information that I don't even know to ask for, please feel free to share it. :)
I'm very knew to DVRs and am trying to find the easiest system at the best possible price. I'd like to avoid subscription fees if possible but if the price is right, I might consider it.
Thanks for all the help,
-- Jeff
jpaq is offline
post #2 of 5 Old 06-24-2004, 01:00 AM
bfdtv's Avatar
No, SA products are not compatible with Motorola head-end equipment, and Motorola products are not compatible with SA head-end equipment.
If your MSO is using Motorola hardware, then you'd need to wait for them to offer the Motorola 6208 or dual-tuner Motorola 6412 DVR. The single-tuner 6208 is available in a number of Comcast markets now, with the 6412 slated for deployment this fall. Alternatively, you could purchase your own CableCard DVR, when those become available (see below).
Generally, COs won't activate current boxes supplied or purchased by the end-user. These SA and Motorola cable DVRs won't work without specific hardware or software supplied by the cable company; in some cases, this software is sent to the boxes over the cable connection, and in other cases, it is preloaded from a computer at the central office.
Comcast does require a digital cable subscription in most areas before they will lease you a DVR. Aside from that and the monthly lease fee (typically, $9.99/mo), there are no incremental charges. The DVR replaces your standalone digital set-top box.
You can always buy your own DVR, like a Tivo or a ReplayTV. These boxes include built-in analog tuners to support the extended basic cable tier (typically, channels 1-99), but generally rely on built-in IR transmitters to control digital cable boxes for digital channels (typically, channels 100+). Whenever there is a scheduled recording from a digital channel (say, 121), the Tivo would send an IR signal, like that from a remote, to change to the appropriate channel at the appropriate time, which it would then record using a s-video (or composite) connection to the digital cable box.
Relying on remote IR signals to control and record content from a separate digital cable box is obviously not the best solution, as this method doesn't support native HDTV or Dolby Digital 5.1 recording. If you only subscribe to the extended basic cable tier, and don't watch HDTV or DD5.1 channels, then a Tivo or ReplayTV is probably your best bet. However, if HDTV or DD5.1 recording is important than you, then you would do best to wait for the DVR supplied by the cable company (Motorola 6208 or 6412), or buy your own CableCard DVR, when they become available.
Unlike current Motorola and SA DVRs, CableCard DVRs are intended for resale directly to the end-user. These DVR products will support and record all digital cable television signals (including HD and DD5.1) directly--without a digital cable box. Authorization will be provided by a plug-in "CableCard" (similar to a PCMCIA card) supplied by your cable company. These access cards will be offered for rental at $0/mo to $2.50/mo; cost will vary by area and provider. Cable companies are required to make these cards available to all customers that request them, effective July 1, 2004.
For an overview of some popular DVR features, you may want to read this post. Not all DVRs are equal in terms of the functionality they offer; some offer all of the features listed in that post, while others operate just like a VCR, except they store recordings to disk, thereby eliminating the need to swap tapes.
bfdtv is offline
post #3 of 5 Old 06-24-2004, 08:03 AM
dt_dc's Avatar
The 8000 (and most digital cable boxes) have an integrated conditiional access system. You're not going to be able to use it with your cable system unless 1) it was specifically sold to work with your cable system or 2) you can get someone (your cable company or SciAtl) to open it up and swap out a chip.
The above also holds true for Mot boxes (in case you were thinking of buying a 6412 when they come out).
Regardless ... you're definately not going to be able to use the box on a system that doesn't support it. As bfdtv noted ... these boxes depend on software on the head-end too ... if that software isn't there ... they won't work.
The reason these boxes are so cheap on Ebay is ... quite frankly ... they're useless.
When CableCard boxes come out ... you'll be able to buy and use them on your cable system. Untill then, don't plan on getting any digital cable boxes from any place other than your local cable company.
dt_dc is offline
post #4 of 5 Old 06-30-2004, 04:19 AM
Qooop's Avatar
So will CableCard boxes be able to plug into a computer for recording content?
What's the point of building a giant robot if you can't blow stuff up with it?
Qooop is offline
post #5 of 5 Old 06-30-2004, 04:40 AM
bfdtv's Avatar
Qooops,
No upcoming DVR (CableCard or otherwise) will let you do with non-local channels. The content is 5C encrypted and the computer can't handle it.
At some point in the future, 5C authorized Firewire cards may become available for PCs, but this is probably several years off, and even then it will probably require a new OS like Microsoft's Longhorn with DRM and content control.
bfdtv is offline
Closed Thread Digital Recorders (PVRs) General
