SA8000HD audio out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-30-2004, 12:00 PM - Thread Starter
1whatnow's Avatar
Just got a SA 8000HD from Time Warner but the both audio digital (opt & cox) out are not supported per TW, is there anyway to make either of these work? I tried the opt, the light was coming thru the cable but it didn't work. Any ideas or am I going to have to wait till Sept.?
1whatnow is offline
post #2 of 4 Old 06-30-2004, 12:14 PM
bfdtv's Avatar
The digital audio output should work fine. Are you sure you've got your Dolby Digital decoder setup correctly, and selected the appropriate option for digital output through the SA8000HD menu setup (press menu twice)?
bfdtv is offline
post #3 of 4 Old 06-30-2004, 10:48 PM - Thread Starter
1whatnow's Avatar
Thanks bfdtv, I'll try that out tomorrow.
1whatnow is offline
post #4 of 4 Old 07-01-2004, 10:04 AM - Thread Starter
1whatnow's Avatar
Bfdtv thanks, it worked. I also was using a bad cable which didn't help.
1whatnow is offline
Closed Thread Digital Recorders (PVRs) General
