iGuide - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #31 of 49 Old 12-23-2004, 11:29 AM
tall1's Avatar
Originally posted by sick_spd
I have the Comcast dual tuner DVR and I have problems with the series pass. No matter what recording options I pick, even though I specify 1st run only I get all the shows. This happens for every show that I have that would be on more then once a week. American Choppers, Mythbusters, Fresh Gear, The Screen Savers, Modern Marvels. Shows like West Wing are only recorded once but last night was an episode from 2003 and it was recorded. Anyone else have or had this problem?
Thanks!!!
Many people...you should read through the thread that markjenna suggested above and you will find the answer to this question and hundreds more. Briefly, the guide data is not always accurate and the iGuide software can not determine if the show is a repeat. I have found it works ok for primetime shows but syndicated stuff it records everything, even repeats. Hence the reason I use manual recordings for Leno and Conan or I get the re-broadcast at 2am recorded also. Good luck.
tall1 is offline
post #32 of 49 Old 12-31-2004, 11:11 AM
MemeSlider's Avatar
OK... Comcast installed my Moto 6412 a couple of hours ago. The 30 sec. skip directions have been posted here a number of times, but I think I must have a different remote. My remote is made by ICX Global and is their model ENT-6412-3005-AB. I can't post links yet, but if you go to:
hxxp://icxglobal.com/en/products/cable/enterprise_family/dct_6412.php
and replace the two little x's with t's, at the beginning of the link, you can see it.
This remote has no SETUP button. Therefore, trying to set the 30 sec. skip following the directions provided is impossible.
Any advice?
Otherwise I like the new box! I have used Tivo before and liked Tivo, but so far I am just as happy with this.
MemeSlider is offline
post #33 of 49 Old 01-13-2005, 02:52 PM
pointnshoot's Avatar
Forgive me if this is the wrong forum topost this in -----
I just got the 6412 and I can't see where you program a series! I can manuall create a recording - that is, program the box to record, either a single event or multiple events, but no place that says "record a series". What am I missing?
Is there - somewhere - a REAL users guide for the 6412 and the remote? Not the little "how to hook it up" booklet, but one that describes how the functions are supposed to work.
And what buttons on the remote do what in which combination. For example - I like that if you push the arrow keys while in live view mode, you can back up. BUT - to get it to play from wherever you back up seems to be a crapshoot. What button CONSISTENTLY plays from that point?
Lots of neat new features but nothing that tells you what's there and how to use it! I don't have time to play 20 questions with the unit. I just want to know what it does and how to make it do it!
I'm sure this has been asked (and answered) before, but short of reading all 10,000+ pages in these forums, I haven't found the answer anywhere, including the Comcast and Moto sites.
pointnshoot is offline
post #34 of 49 Old 01-13-2005, 03:30 PM
tall1's Avatar
Here is the iGuide user manual.
Page 37 discusses rewind and play. Page 40 shows how to setup a series recording.
You should read this thread. good luck.
tall1 is offline
post #35 of 49 Old 01-24-2005, 03:37 PM
slanoue's Avatar
Hi, everyone. I got the DVR last week and I love it! I am hooked! How did I ever live without it? :)
Anyway...the cable guy who hooked mine up didn't really know much about it (I had to help him figure it out). He hooked up my VCR with the audio/video cables rather than coaxial ones. Is this normal?
I was looking over the guides. On this one
URMD2.pdf
If you look at page 9 and 10 where it shows you the back of the box and what everything is for, the first thing it says is:
TO TV/VCR This coaxial output connector is used to connect the DCT6208 to a TV or VCR operating on channel 3 or 4.
However, if you look at the diagram, there is no connector like that. I looked at the back of my box, and it's the same.
~~Suzanne Lanoue~~
http://suzann.com
http://tvmegasite.net
me@suzann.com
slanoue is offline
post #36 of 49 Old 01-24-2005, 04:29 PM
Thanks! I'm overseas right now but my wife tells me we received a guide inthe mail that, fromthe sound of it, should answer all my questions! Seems Comcast failed to give me the guide when I picked up the unit.
post #37 of 49 Old 01-24-2005, 05:55 PM - Thread Starter
markjrenna's Avatar
Quoted: 13 Post(s)
Comcast NJ - Union/Verona
Yes it is. Mine is connected via RCA or Composite.
Check this thread for future refference...
http://www.avsforum.com/avs-vb/showt...hreadid=464986
markjrenna is offline
post #38 of 49 Old 01-24-2005, 09:59 PM
slanoue's Avatar
So, you don't know why the guide says there's a coaxial connection when there's not?
How many pages do I have to read through to get other info? Man it's a big thread.
I get a little confused, what is DVI and how do I hook up my DVD recorder/player? right now I have it going through the VCR.
~~Suzanne Lanoue~~
http://suzann.com
me@suzann.com
slanoue is offline
post #39 of 49 Old 01-25-2005, 05:55 AM - Thread Starter
markjrenna's Avatar
Quoted: 13 Post(s)
6208 has RF out (Coaxial).
6412 does not have RF out.
If you have no RF out then you have the 6412 dual tuner DVR.
DVI is primarily used to connect HD components such as a Plasma HD TV.
Unless your VCR and DVDR support other connections, for example; SVideo, Component, etc..., you have it connected properly.
You may want to consider running your equipment through a Home Theater Receiver. But that means more equipment and expense.
I realize it is a big thread since I helped create it. But it contains a plethora of information related to the 6412 and i-Guide. I suggest you at least refer to it by doing a Search when you have a question or concern. It may have already been discussed.
Mark
post #40 of 49 Old 01-25-2005, 06:33 AM
slanoue's Avatar
Thanks for your help!
I tried reading it through...my eyes started getting blurry by page 9 :)
It was very helpful, though.
~~Suzanne Lanoue~~
http://suzann.com
me@suzann.com
slanoue is offline
post #41 of 49 Old 01-27-2005, 08:56 PM
scanpa's Avatar
No idea why the ondemand button would use "1 9" but you could simply hit 1 instead of 01. You may have the AUTOTUNE turned on which requires you to type the leading 0, so to turn this leading zero requirement off....in the setup menu, choose cable box options, then under AUTOTUNE, choose no.
Here is all the codes and info for the current remote used for the Comcast DCT 6412
http://cjhengineering.com/hdtv/cable...12remoteAC.htm
Main page; http://cjhengineering.com/hdtv/cablehdtv/dct6412.htm
Comcast of Lebanon PA.
scanpa is offline
post #42 of 49 Old 03-24-2005, 08:00 AM
ssetta's Avatar
I think I might get this Comcast 6412 Dual Tuner DVR. But I need to know: How many RCA outputs does it have on the back? I currently have DirecTV, and from one of the RCA outputs, I have the DTV Receiver connected directly to the TV, and from the other one, I have it connected to my DVD recorder, and then to the TV. Does the 6412 have that capability?
ssetta is offline
post #43 of 49 Old 03-24-2005, 08:04 AM
ssetta's Avatar
Oh, and I just forgot, my TV doesn't actually have HDTV capability. But will the HDTV channels still come in?
ssetta is offline
post #44 of 49 Old 03-24-2005, 01:41 PM
scanpa's Avatar
Do you have a S-Video input conection on the back of your tv?
scanpa is offline
post #45 of 49 Old 04-01-2005, 12:47 PM - Thread Starter
markjrenna's Avatar
Quoted: 13 Post(s)
Comcast updated the i-Guide Instruction Manual (PDF) and created a 6412 Installation/Connection Manual (PDF).
i-Guide Instruction Manual (PDF) http://www.comcast.com/MediaLibraryR...uide_4469a.pdf
6412 Installation/Connection Manual (PDF) http://www.comcast.com/MediaLibraryR...lfMoto.r33.pdf
post #46 of 49 Old 03-14-2006, 09:56 AM
DAB
DAB's Avatar
Quoted: 26 Post(s)
{ can you PM me here- so i'll get the answer}
How do you tell the box to send 480ior780 to a plasma? or when it comes 1080,.
Or does the box send all signal and the plasma -set to auto- picks an chooses.
db
DAB is offline
post #47 of 49 Old 03-14-2006, 10:06 AM
cherry ghost's Avatar
Quoted: 18 Post(s)
db
With the TV on and the cable box off, press menu on the remote.
cherry ghost is offline
post #48 of 49 Old 03-14-2006, 12:05 PM
DAB
DAB's Avatar
Quoted: 26 Post(s)
OK i hit the comcast -menu-, in the box led it showed 16.9. I have a HD 50NECxr5.
connected HDMI- direct box > plasma
so this what i want?- 16.9
DAB is offline
post #49 of 49 Old 03-14-2006, 12:30 PM
Quoted: 18 Post(s)
Yes, 16:9
Closed Thread Digital Recorders (PVRs) General
