Toshiba SD-H400 DVR question - AVS Forum | Home Theater Discussions And Reviews
Old 09-30-2004, 03:35 PM - Thread Starter
LSM
LSM's Avatar
I have searched this forum with no finds about the Toshiba SD-H400 DVR so maybe somebody can help me.
My question is that the Toshiba SD-H400 specks and blurbs mention that it will play back recorded material from its hard drive to a HDTV using the progressive component outputs. Does the SD-H400 actually record HD shows and play it back to a HDTV in "unmodified" HD as i.e. the Motorola 620x STB would or convert the signal to analog first?
This is a great forum with many knowledgeable folks.
Thanks in advance for any help on this question.
LSM
UPDATE...
OOPS! It seems I missed the sticky post about TIVO sister site. Found this post...
"It seems you are not going to benifit from taking the HD signal onto a tivo. I have the toshiba SD-H400 which has component out, so when a program is broadcast in HD or widescreen it saves on the tivo in 16:9 aspect. Although the quality does suck"
Thanks anyway!
LSM is offline
Old 09-30-2004, 03:59 PM
Stephen Tu's Avatar
The Toshiba model in question is a Tivo / DVD Player combo, so you would find a zillion threads about it in the Tivo forums, not this one.
It is a standalone PVR, encoding from analog sources only so it will not record in HD. It doesn't "convert the signal to analog first"; you have to feed it an analog signal to begin with. In order to record from a HD channel, you would need an HD cable box; the cable box would convert the signal to analog NTSC (480i), the Toshiba then would take that, digitize & MPEG encode it & store to disk.
If you want to actually record in HD you need a integrated digital tuner/DVR, such as the Motorola 6208/6412, SA 8000HD for cable, or the DirecTV HR10-250 HD-Tivo model for satellite/OTA.
Stephen Tu is offline
Old 09-30-2004, 04:33 PM - Thread Starter
LSM
LSM's Avatar
Thanks Stephen for your response. I did find the TIVO board and learned that the TIVO based units do not use HD at this time. I do have the Motorola 6208 and was trying to work around its poor TV Guide I/F.
LSM
LSM is offline
