720p on hd 8000?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-13-2004, 05:23 PM - Thread Starter
tfunk02's Avatar
What is the default resolution on the hd 8000, and if it isn't 720P, how do I change it to that? Thanks!!!
I have a Sanyo Z2 that is 720p. On the old box I had all I had to do was press menu while the box was turned off, but I need help on this box.
tfunk02 is offline
post #2 of 2 Old 10-15-2004, 02:56 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 512 Post(s)
Liked: 772
I don't think there's a "default resolution" of the SA8000HD.
To change the output formats, press the SETTINGS key on the remote then hit the A key for MORE SETTINGs and scroll down a few notches and you'll see Outup Formats. There you can select one or any of the available formats.
In my case i have a Panasonic HDTV and it doesn't input or support 720p at all so i have to de-select 720p completely. If i have 720p as one of my formats, when i tune to KABC-HD or ESPN-HD my TV screen goes black since both stations broadcast in 720p.
So i have 480i, 480p, and 1080i selected as my output formats.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Closed Thread Digital Recorders (PVRs) General
