sa 8000 hd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-25-2004, 10:21 PM - Thread Starter
fastlane2546's Avatar
Anyone know when the DVI will be active on SA 8000hd. Last I was told it would be Sept. that was wrong anythink new.
fastlane2546 is offline
post #2 of 4 Old 10-26-2004, 01:25 AM
bfdtv's Avatar
Who's your provider? It will vary by cable provider and market.
Some have it now (though it doesn't work very well with many displays), some should get it in late November, and others probably won't see it before January or February.
Fyi, posts relating to HDTV recorders like the SA8000HD belong in the HDTV Recorders forum. That's the place to look for the latest information on DVI support and rollout.
bfdtv is offline
post #3 of 4 Old 10-26-2004, 07:20 AM - Thread Starter
Charter Ma;ibu Ca. Thanks for the info.
post #4 of 4 Old 10-26-2004, 11:09 AM
bfdtv's Avatar
Charter is behind the times with their SA8000HD software deployments; you'll be lucky to get DVI support by January.
bfdtv is offline
Closed Thread Digital Recorders (PVRs) General
