S/A Explorer 8000 - How to Format HD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-23-2004, 04:41 PM - Thread Starter
eworld's Avatar
I use Brighthouse Networks in Orlando, FL and would like to re-format or defrag the HD in my Scientific Atlanta Explorer 8000 box.
The instructions I've tried (with no results) are as follows:
Using the REMOTE CONTROL Push CBL button
Then hold down Pause Button until you see a Green Flashing light on box
(This never has worked... No flashing lights nadda)
Push the Page down (minus -) Button once
Push the List Button 3 times
So far NO LUCK... Any ideas?
eworld is offline
post #2 of 2 Old 11-24-2004, 06:51 AM
TMTBoomer's Avatar
http://www.avsforum.com/avs-vb/showt...hreadid=473669
You should pick a forum and stay with it. ;)
-Boomer
TMTBoomer is offline
Closed Thread Digital Recorders (PVRs) General
