Noisy Motorola DCT6412 - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2004, 06:11 PM - Thread Starter
DevlinNulland's Avatar
Hi there!
I just got a Motorola DCT6412 combo HD/DVR box from Comcast, and I'm hearing a noise I didn't expect from it. It's much like a hamster running in a hamster wheel or a fan that is slightly out of balance( i.e. the noise isn't completely smooth). It kind of sounds like "chika-chika-chika". I can hear it from my couch 10 feet away, though I do have a quiet room and a good pair of ears, heh. Now I know the hard drive is running all the time (and the sound seems to be coming right from it), but from all the computers I've built I've never heard such a noisy drive. If I did, I'd assume the drive was a super cheap one or that it was about to fail on me.
BTW, the box seems to record and function normally. The one odd thing I see is that if I shut off the box (which causes the noise to stop), the red record light comes on even though I have nothing scheduled to record.
Any similar experiences out there? Is this sound normal for a DVR?
Dev
DevlinNulland is offline
Old 12-05-2004, 08:05 PM
nmilot's Avatar
I just picked up a dvr box through comcast the other day. The sound was the first thing I noticed. I did see it mentioned on a review somewhere that it is somewhat noisy. You don't notice it when the tv is actually on, but with the tv off it is noticeable.
nmilot is offline
Old 12-06-2004, 10:53 AM
scalag's Avatar
I have a SA8000 and it makes the same noise as you describe. I've had it for over a year and it works fine. The first one I had was very quiet and the hard drive failed in less than a year. Maybe noise is a good thing.
scalag is offline
Old 12-08-2004, 02:47 PM
julkruk's Avatar
I hear the same noise with my brand new 6412 and I get the same red light when I turn it off.
julkruk is offline
Old 12-18-2004, 02:08 PM
Bill Ball's Avatar
Quoted: 89 Post(s)
Liked: 88
The hard drive in the 6412 is noisier than in my D'TV TiVo box. It's only audible under very quiet conditions and primarily on startup and when swtiching channels. The TiVo is silent. So, I agree, but it is not loud enough to intrude on listening.
Bill
LG 65LA9650 (upgraded)
Onkyo TX-SR876
ADS L520 fronts
BIC Acoustech PL-26 center
Mirage Omnisat V2 surrounds
Minix NEO X8-H Plus Android media box
Bill Ball is offline
Old 12-20-2004, 09:28 AM
malvado's Avatar
they're all definitely loud, but a number of the units are substantially louder than others. comcast has had a number of calls on this, so call someone out, and the least that would probably happen would be that the tech might swap the unit out to make you happy.
malvado is offline
