SA 8000 and 8300 HD PVRs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-08-2004, 10:09 AM - Thread Starter
Tim Gray's Avatar
What's the difference between these boxes?
thanks.
Tim Gray is offline
post #2 of 6 Old 12-08-2004, 11:14 AM
Juiceroc's Avatar
The 8000 is unable to push out HDTV signal, the 8300 is able to. Also, the 8300 has an HDMI output and an SATA port on the back of it.
Juiceroc is offline
post #3 of 6 Old 02-04-2005, 07:19 AM
tattooedbones's Avatar
It is my understanding that there are technically 4 models: 8000/8300 and 8000HD/8300HD. A major difference, at least between the HD models is that the 8300 has double the capacity of the 8000. 8000HD has an 80 GB drive while the 8300HD has a 160GB drive. Also, yes- the 8300HD has HDMI and SATA connections.
tattooedbones is offline
post #4 of 6 Old 02-04-2005, 07:55 AM
dt_dc's Avatar
There's also the 8300MR and 8300MRHD ... "MR" = "Multi Room" ... adds a QAM modulator for multi-room viewing via coax on other digital cable STBs.
dt_dc is offline
post #5 of 6 Old 02-06-2005, 06:49 AM
TheDreamer's Avatar
My 8000 had an 80GB drive, but my 8000HD has a 160GB drive.
The Dreamer
You may be a dreamer, but I'm The Dreamer, the definite article you might say!
TheDreamer is offline
post #6 of 6 Old 02-06-2005, 10:41 AM
work permit's Avatar
Quoted: 12 Post(s)
The picture quality on the 8300HD is much better then the 8000HD
Alex
work permit is offline
Closed Thread Digital Recorders (PVRs) General
