DVR recording to DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-16-2004, 02:24 PM - Thread Starter
pabs's Avatar
Is there a way to record from a Comcast DVR (motorola) to a standard DVD recorder (not connected to a computer) without having to sit and record/view the recording in real time?
pabs
pabs is offline
post #2 of 13 Old 12-16-2004, 02:41 PM
archiguy's Avatar
Quoted: 3939 Post(s)
Liked: 4090
And you posted this in the HDTV Recorders Forum....why?
archiguy is online now
post #3 of 13 Old 12-16-2004, 06:34 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Because he thinks his DVD recorder is HD :D
Foxbat121 is online now
post #4 of 13 Old 12-16-2004, 06:41 PM
zeroendless's Avatar
so you know, pabs... you can't put even 1 hour of HD stream recording into DVD if there's one. Get you a DVHS tape recorder probably much helpful.
zeroendless is offline
post #5 of 13 Old 12-20-2004, 12:31 PM
SilverHemi03's Avatar
Where would you ask the question of recording SD from a Moto 6412?
I want an interim solution while I build a HTPC. On the DVD recorder forum, there isn't much discussion on the 6412 since it's HD. I want to use the 6412 to record everything, then selectively burn some SD DVD's to release the space.
SilverHemi03 is offline
post #6 of 13 Old 12-26-2004, 11:56 AM
lisa6191's Avatar
<<Where would you ask the question of recording SD from a Moto 6412?
I want an interim solution while I build a HTPC. On the DVD recorder forum, there isn't much discussion on the 6412 since it's HD. I want to use the 6412 to record everything, then selectively burn some SD DVD's to release the space.>>
I would like to know this also. I posted in the general DVR forum but nobody seemed to know how to do it. My situation is further complicated by the fact that I am routing everything through my Onkyo receiver first. Would I need to connect the 6412 directly to the DVD recorder without going through the receiver first? If so, what connections would I use? Thanks for any help with this!
-Lisa
lisa6191 is offline
post #7 of 13 Old 12-26-2004, 06:04 PM
Jimbo Moran's Avatar
-Lisa
Purchase an S-Video cable then run it to your DVD Recorder from your 6412 since it outputs video on all connections at once. You will also need some RCA cables to your recorder for audio. You can simply run a set from yout 6412 if you are currently using a digital connection to your receiver.
Jimbo--------Bomb's Away
Jimbo Moran is offline
post #8 of 13 Old 12-27-2004, 10:10 AM
Almighty1's Avatar
Quoted: 97 Post(s)
Liked: 27
That would work but the other issue is that DVD Recorders also record the 5.1 Dolby Digital track so wouldn't RCA cables only give 2 channel sound or can the 5.1 information still make it to the DVD Recorder?
Cheers,
Vince, Ph.D. - Astrophysics
Almighty1 is offline
post #9 of 13 Old 12-27-2004, 12:21 PM
I am unaware of any DVD recorders that record in DD5.1. Which unit were you using as an example?
post #10 of 13 Old 12-28-2004, 08:14 AM
Almighty1's Avatar
Quoted: 97 Post(s)
Liked: 27
The LG XBR446 VCR/DVD-+R/RW does record in DD5.1.
Cheers,
post #11 of 13 Old 12-28-2004, 08:16 AM
dsmith901's Avatar
Liked: 24
The question here is one I have also. There is lots on the non-HD channels I would like to record, and I am curious to see if I can record HD channels (downconverted to 480i through the S-video out) also as it may provide better PQ. The 6412 video is connected to my ED plasma through component cables. I plan to run the S-video out to my Panny E80 but there is only one set of analog outs (and I want to keep that to the TV even though the digital out runs to my surround system), so I will need to split both channels of the audio and run one to my TV and one to the E80. As far as I know the 6412 will have to be in "Play" mode to make the recording in real time. But you could set that up to run overnight and it won't interfer with recording.
"The truth is out there!"
dsmith901 is offline
post #12 of 13 Old 12-28-2004, 11:10 AM
SonomaSearcher's Avatar
Moved to non-HD DVR forum, since it has nothing to do with HD.
SonomaSearcher is offline
post #13 of 13 Old 12-28-2004, 08:02 PM
I don't believe it does however I cannot find the input specs anywhere online. Do you own this unit and does it have a digital audio input? If so it might be worth picking one up if for no other reason than the audio recording capability.
Closed Thread Digital Recorders (PVRs) General
