The Comcast/Motorola DCT-6412 Discussion Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 53 Old 12-25-2004, 03:27 PM - Thread Starter
s.bradford's Avatar
It would be nice to get a category for this DVR, but until then maybe this will do.
I have had this unit for about a week and I am pretty impressed (far more than I thought I'd be based on somethings I have heard and been told).
I like the new guide, especially the 'view by channel option', the dual tuners and dual buffers you can swap between and the fact that you can still see what your viewing on any screen, and I like being able to sort the recordings list by various methods.
Most of all I like having everything in one interface. It does have a couple of minor quirks but I am confident these will be addressed.
In fact I really think it could replace my ReplayTV entirely if only I could get more storage. So the big question is... what about more storage.
Has anyone heard of plans for bigger drives (official word, hacks, whatever)? I searched the net and found nothing. Maybe it is too new, but I figure somebody, somewhere has to be planning something.
s.bradford is offline
post #2 of 53 Old 12-26-2004, 02:57 AM
smash's Avatar
I'm not sure if anyone's taken the box apart yet or attempted to mess with this. I'm sure if you made a direct replica of the comcast drive and put your own in, it might work. Also, I was shown how to format the drive in the box but my comcast when mine got corrupted. You might want to try doing that after just putting a new one in and see if it'll just wipe it.
to format the drive, you go into diagnostics mode (turn the box off then immediately press select) then press replay, replay, replay, my dvr, my dvr, my dvr, live, live, live. that quick formats the drive. give it a try.
- smash
Check out my website... http://www.smashsworld.com/
smash is offline
post #3 of 53 Old 12-26-2004, 08:36 AM - Thread Starter
s.bradford's Avatar
Interesting, but I am pretty sure that would just wipe a storage partition. There must be another partition that contains the OS and other software. The replacement drive would need to have that installed, but at this point I don't even know what OS the box is using or what file system the drive uses.
post #4 of 53 Old 12-26-2004, 06:22 PM
MemeSlider's Avatar
I would be interested in hearing if anyone has successfully transferred saved shows to their Mac.
I will be getting the 6412 on Thursday and will try to do some experimenting with the firewire connection and Virtual DVHS. I will post my findings!
MemeSlider is offline
post #5 of 53 Old 12-27-2004, 08:40 AM - Thread Starter
s.bradford's Avatar
I just discovered there is already an official thread for this device in the HDTV Recorders Forum.
post #6 of 53 Old 12-28-2004, 09:35 AM
markjrenna's Avatar
Quoted: 13 Post(s)
Comcast NJ - Union/Verona
Yes... Please refer to these threads...
http://www.avsforum.com/avs-vb/showt...hreadid=449214
http://www.avsforum.com/avs-vb/showt...hreadid=464986
markjrenna is offline
post #7 of 53 Old 01-02-2005, 10:55 PM
mdec's Avatar
can anyone tell me what the final word is regarding archiving content to DVD from the 6412 firewire link ?
mdec is offline
post #8 of 53 Old 01-09-2005, 05:07 AM
bobwsx's Avatar
i'm sure this has been answered.sorry for the stupid question but,can i hook the dvr(6412)to my laptop?if so do i need any software?do i use ethernet or usb?
bobwsx is offline
post #9 of 53 Old 01-13-2005, 10:03 AM
mismatched's Avatar
Does anyone know whether the 6412 is adjustable, brightness, contrast, color etc??? And does comcast broadcast HD test patterns to record and use for adjustment using Avia or DVE??
thanks
mismatched
mismatched is offline
post #10 of 53 Old 01-26-2005, 12:33 AM
RScottyL's Avatar
Yes, you can hook the 6412 to your laptop.
You will need a firewire connection on your laptop.
You will also need CAPDVHS software.
RScottyL is offline
post #11 of 53 Old 01-27-2005, 10:50 AM
hdtvordie's Avatar
My laptop doesn't have firewire, is there any way to do it via the USB port or the Ethernet port? I do have a USB Hauppage TV Tuner as well.
Any info you can provide would be appreciated.
-Tony
hdtvordie is offline
post #12 of 53 Old 01-27-2005, 03:06 PM
scanpa's Avatar
The USB ports & Eithernet Ports are not enabled with the current software!
You can look for a Firewire board for your laptop from most Computer retail places, like Office Max or by looking online.
The software can be downloaded via several links located in other posts on this website, use the search feature to find them.
Good Luck!
Comcast of Lebanon PA.
scanpa is offline
post #13 of 53 Old 02-11-2005, 07:09 AM
hdtvordie's Avatar
I got a Firewire card for my laptop, and I have video capture software, however XP is not finding the driver for the Motorola box.
Does anyone know where I can find a driver for it?
-Tony
post #14 of 53 Old 02-15-2005, 07:39 PM
scanpa's Avatar
-Tony
scanpa is offline
post #15 of 53 Old 02-19-2005, 07:28 PM
Matt Weldy's Avatar
Is there a way to just go to the dvr hard drive and copy the file. Instead of have to watch it on the pc and record (like a vcr).
Matt Weldy is offline
post #16 of 53 Old 04-28-2006, 02:08 PM
pfalcon's Avatar
- smash
The steps here list how to do a quick format, but to get to the basic diag modedo you just turn the box off then immediately press select?
Does anyone know what other things you can do in the diagnostic mode?
-Steven
pfalcon is offline
post #17 of 53 Old 07-12-2006, 07:40 PM
ronr1999's Avatar
At least the UPS port is powered...
RonR
ronr1999 is offline
post #18 of 53 Old 01-07-2007, 12:12 PM
ed71's Avatar
My DVR has been recording without trouble, however, I have been unable to play anything I have recorded for the past 48 hours. When I try to playback something I have recorded, I get a blank screen except for the counter. When I stop and exit the DVR section, the screen remains blank until I change channels. Any suggestions?
ed71 is offline
post #19 of 53 Old 01-12-2007, 10:24 AM
norburban's Avatar
I had a similar playback issue. It was resolved after a cold restart. Unplug the unit, wait a few seconds, plug it back in. It'll take several minutes for the DCT to load back, but you should be good to go after that.
norburban is offline
post #20 of 53 Old 01-12-2007, 11:41 AM
mismatched's Avatar
I agree. When in doubt.... Reboot
post #21 of 53 Old 02-01-2007, 03:47 PM
mismatched's Avatar
Has anyone out there switched to the Motorola 3412 from their old 6412? Having freezing and bad hard drive sector(s) issues with my 6412. On another site I am getting some poor reviews of the 3412.
Comments, first hand experience of anyone out there
thanks
Mismatched
post #22 of 53 Old 02-02-2007, 03:31 AM
bicker1's Avatar
I went from a 6412 to a 3412, and from there to a 3416. Stability has continually increased. I think, however, that has more to do with improvements in the firmware (which would be applied to that running on all three boxes, equally), and just luck-of-the-draw with regard to hardware quality. There are evidently a good number of sensitive components in these boxes, and they suffer from both infant mortality (in which cases older boxes would be better) and from wear-out and damage from mishandling (in which cases newer boxes would be better).
bicker1 is offline
post #23 of 53 Old 02-16-2007, 07:40 PM
Corsair0022's Avatar
I have a 80GB Seagate HDD out of a 6208 DVR box that had been run over several times (because the box was bad). I pulled the drive out of the box. I hooked it up to my tower and it still reads but I want to be able to read the data on the disk. Does any one know how to do this?
Corsair0022 is offline
post #24 of 53 Old 02-16-2007, 09:06 PM
scanpa's Avatar
That HDD will only be usable on the STB that it was formated on. DRM and other codes will prevent it from being read on another STB, also you will not be able to access any of the STB Files on that HDD via PC.
When the HDD is formated by the STB, it is mated to only work on that STB.
scanpa is offline
post #25 of 53 Old 02-17-2007, 10:10 AM
MrMike6by9's Avatar
Or to put it another way, even when working properly, I've heard that saved content on the unit cannot be played back if the box can't call home due to a service outage.
YMMV
"Typos are very important to all written form. It gives the reader something to look for so they aren't distracted by the total lack of content in your writing."
- Randy K. Milholland
MrMike6by9 is offline
post #26 of 53 Old 02-20-2007, 12:06 PM
GFelizardo's Avatar
Will the 6412 (or any newer Comcast box) output 16:9 via the S-video output?
GFelizardo is offline
post #27 of 53 Old 02-20-2007, 12:15 PM
scanpa's Avatar
The S-Video output will only do SD Widescreen not full 16:9.
scanpa is offline
post #28 of 53 Old 02-23-2007, 06:00 AM
G-star's Avatar
Quoted: 18 Post(s)
i'm in the philly burbs, and comcast just sent out a firmware update (12.18 --> 12.31) for the 6412. no more loss of DD 5.1 audio after pausing or rewinding live TV, which is a great thing. however, the "My DVR" button no longer calls up the list of recorded shows...just a blank screen with some jibberish on top.
anyone else have this problem?
"That's right Mr. Martini...there is an Easter Bunny".
G-star is offline
post #29 of 53 Old 02-23-2007, 06:07 AM
Joe_M's Avatar
Yep, seems like they thoroughly tested everything before the update. You need to pull the plug to power down the unit and plug it back in. After a few minutes everything will be back.
There is no "best", best is what's best for you...
Have you tried searching first?
Joe_M is offline
post #30 of 53 Old 02-23-2007, 01:59 PM
johnliska's Avatar
I have Mot. 6412 it has worked fine, so far, put since american idol started this season it will not record (for my wife) i have tried every thing even called cable provider and they reset the box > still nothing. also i know it is in here some where but i would love it if someone could put in laymans terms how to hook up a laptop and save files on a external. hard drive. What format dose PVR save shows in ?
all info on this site is great it is nice to people share their brain power so freely.
johnliska is offline
Reply Digital Recorders (PVRs) General
