Comcast DVR --> DVD recorder connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-11-2005, 03:01 PM - Thread Starter
lgussow's Avatar
Just got a dual tuner DVR from Comcast. It is connected to the TV, but I'm also trying to connect it through a DVD recorder into a second TV input. Used RCA connectors from DVR-out to DVD in. Get nothing but a blue screen. the DVD -> TV connection is good, since DVD's play fine. Any suggestions? Thanks. Gus
lgussow is offline
post #2 of 5 Old 01-11-2005, 06:31 PM
Stingray1's Avatar
If you're using the SA8000HD, it won't output to the component out and composite/S video out at the same time. To get program to your DVD recorder - record to you DVR hard drive then use the "copy to VCR" mode to download to DVD recorder. You can still use the SA8000HD to record, play other recorded programs , or watch a live channel while doing the download. Its a little awkward but not too bad once you get used to the process.
Stingray1 is offline
post #3 of 5 Old 01-16-2005, 06:25 PM
gillcup's Avatar
Quoted: 101 Post(s)
Liked: 4269
Stingray1,
Could you explain what "copy to VCR" mode is?
Mark
gillcup is offline
post #4 of 5 Old 01-17-2005, 10:37 AM
SonomaSearcher's Avatar
Since not all dual tuner cable DVR's are the same, it is necessary to describe the brand/model that you have. Also, describe the software/guide it uses. And your specific location is always helpful.
Moved this thread since it does not concern HD issues.
SonomaSearcher is offline
post #5 of 5 Old 01-18-2005, 07:14 PM
Stingray1's Avatar
gillcup - to use the "copy to VCR" mode on the SA8000HD, press the "mydvr" button in the upper center of the remote. This will bring up a list of the recorded programs on the DVR hard drive. Highlight the recording you wish to copy, press the select button - the menu that pops up will contain a "copy to VCR" option.
Closed Thread Digital Recorders (PVRs) General
