What STB model(s) will I get from TWC if I get their DVR service? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-11-2005, 04:35 PM - Thread Starter
jet190rs's Avatar
This is for non-HDTV, so I assume its not the SA8000HD or SA83000HD that everyone is taking about on these forums....
Please let me know what box they currently offer for SDTV and if they have analog or svideo outputs in the back (because I want use a dvd recorder or the dvd burner from my pc)
BTW, I'm located in NYC if location make any difference.
Rich
jet190rs is offline
post #2 of 6 Old 01-12-2005, 09:04 PM
HooDSide's Avatar
I have both a SD DVR and a HD DVR from Time Warner NYC.
SD= SA8000
HD= SA8000HD
Enioy
HooDSide is offline
post #3 of 6 Old 01-18-2005, 01:49 PM
gus8av's Avatar
I have an SA8000HD from Time Warner. I assume from reading elsewhere that TW uses the 'Passport' software in the SA8000HD. My question is a non-DVR question. The remote has a Favorites key but I can't find out how to use it to restrict the list of channels when I press the channel up/down key. Can anyone help, or is this a non-implemented function in this STB?
thanks.
gus8av is offline
post #4 of 6 Old 01-18-2005, 02:36 PM
gus8av's Avatar
I figured it out. You select the desired channel, press Settings, then left arrow, then exit. Then select another channel and repeat.
gus8av is offline
post #5 of 6 Old 01-19-2005, 07:20 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Some TWC affiliates use Pioneer Passport software but other TWC affiliates use the SARA software so you have to check your DVR to see what your particular TWC office is using. It's also a good idea to know which version of either software is currently on your machine. Luckily i have Passport on my DVRs :D
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 6 Old 01-19-2005, 09:24 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
Originally posted by jet190rs
This is for non-HDTV, so I assume its not the SA8000HD or SA83000HD that everyone is taking about on these forums....Please let me know what box they currently offer for SDTV and if they have analog or svideo outputs in the back (because I want use a dvd recorder or the dvd burner from my pc)
Actually you should call the cable company and ask them which non-HD DVR they give you, and also ask if they run Pioneer Passport or SARA software. These two questions will be a big help in finding out about recording to DVD.
I seem to remember seeing mention of a non-HD SA8300 here and there, but some cable companies might give you the SA8300HD and have you run it in SD mode which would be the best possible scenario. More likely it'll just be the regular SA8000 and i don't think you can easily record to DVD (if at all).
Ask them if they have the SA8300 or SA8300HD, and if so can you get one of those. And remember to ask what software they're running.
Randy
Closed Thread Digital Recorders (PVRs) General
