Cost for 2nd Comcast 6412 - AVS Forum | Home Theater Discussions And Reviews
Old 02-03-2005, 01:01 PM - Thread Starter
cld3's Avatar
I've had the Comcast 6412 for a couple of months and have been pretty happy with it. I was thinking of adding a second one in the guest room and figured it would be an extra 9.95 a month. Comcast says I will be charged 18.95 monthly to add the second 6412 - 9.95 for the box and the rest a
"digital service charge". Does this sound right? Is this what others are paying?
cld3 is offline
Old 02-07-2005, 08:28 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
That may be about right - where i'm at TWC would charge an additional $6.60 for the DVR rental itself, $9.95 for the "DVR Service" (the ability to record), and another $2.95 "additional room charge".
I have two DVRs connected to my one TV and made them take away the additional room charge they'd tacked onto my bill since both DVRs are in the same room.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 02-15-2005, 10:45 AM
scottro's Avatar
Suggestion: I was in the same situation, and it would cost about an extra $16 here in Pittsburgh. Since I primarily wanted to watch recorded materials on an old 19" (complete with faux woodgrain panels) while I exercised in my "workout room", I picked up a wireless A/V sender/receiver at Radio Shack ($80). It transmits audio, video, and remote signal quite nicely without the additional box. So I'll break even on the deal in 5 months.
Works pretty well, sometimes get some interference or ghosting, but not often. Better than giving an extra $16 to Comcast for a box I'll use a few hours a week.
Of course this only works if the TV with the STB is not in use since it just transmits whatever is being watched to the receiver. I split the coax feed direct to the TV so the wife can at least watch the analogs if need be while I'm watching something from the DVR in the other room.
scottro is offline
