Can you connect toslink to coax? - AVS Forum | Home Theater Discussions And Reviews
Old 02-06-2005, 11:47 AM - Thread Starter
karpa's Avatar
How do I connect my toslink digital audio output to my home theater system which only has for it's digital input S/PDIF coaxial? My new DVR only has toslink... Please help
Carol
karpa is offline
Old 02-06-2005, 01:14 PM
work permit's Avatar
Quoted: 12 Post(s)
I use a midiman co2 for this sort of conversion. They allow you to go both from optical to coax, or coax to optical.
Its overkill for what you want to do (since it goes both ways). There are cheaper solutions that will just convert optical to coax.
Alex
work permit is offline
Old 02-06-2005, 02:36 PM - Thread Starter
karpa's Avatar
Thanks soooo much! You are a lifesaver!
Carol
karpa is offline
Old 02-06-2005, 07:49 PM
Thinker's Avatar
I've bought several of these things on eBay. ABout $15. Make sure you get the one you need: opt-to-coax is not the same as coax-to-opt.
Thinker is offline
Old 02-06-2005, 07:58 PM - Thread Starter
karpa's Avatar
Thanks Thinker!
Carol
karpa is offline
