SA8000/8300HD output question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-15-2005, 10:31 AM - Thread Starter
scasmflop's Avatar
On my old HD tuner, I could set it up to output through DVI and S-video simultaneously. This way I could switch my TV's input to the correct video mode depending on if I was watching an HD channel or SD. Is there any way to do this with either of these boxes?
I just received the SA8000HD yesterday, and it outputs DVI or S-video, but has no options to have both active at the same time. I'm also having a lot of problems with it failing to recognize the HDCP compliance of my set (XBR34910). Seems to do fine if you channel up or down to the channel, but not if you enter the channel directly?
scasmflop is offline
post #2 of 3 Old 02-15-2005, 11:24 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
I just received the SA8000HD yesterday, and it outputs DVI or S-video, but has no options to have both active at the same time.....
The SA8000 only has one output active at any time. The SA8300 has all outputs active, but HDMI may or may not be enabled in your area.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 3 Old 02-15-2005, 01:48 PM
Texas Aggie's Avatar
My HDMI is active BUT my PJ only has HDMI. I got a HDMI to DVI conversion cable ut there is a LOT of noise!
Called DWIN and they said that they recommend only a DVI to DVI set up.
argh
Texas Aggie is offline
Closed Thread Digital Recorders (PVRs) General
