Comcast/DVR trouble - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-17-2005, 06:00 PM - Thread Starter
ferdelance's Avatar
Comcast applied some "patch"(according to the tech I spoke with)which now will not let me watch one show and record another(I have the dual tuner DVR DCT6412)not only that but now rather than just recording at the push of rec button, this stupid screen comes up which asks for start/stop time.
The tech also asked if the dual tuner DVR ever let you watch & record separately!!! Of course it did, it's not working that's why I'm calling.
Anyone else experiencing this problem with their Comcast/DVR ?
ferdelance is offline
post #2 of 3 Old 02-18-2005, 07:15 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Does the Motorola DVR use Pioneer Passport software? If so which version is it?
If it is Passport, instead of hitting the Record key try bringing up the guide first, highlight the show you want, then hit the Record key. I think by just hitting the Record key alone it's giving you the option of Creating a Manual Recording that's all. I have an SA DVR with Passport but it should work the same on the Motorola unit.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 3 Old 02-28-2005, 04:07 PM
RobbyGT's Avatar
I had 3 boxes switched out in the first 6 months last year.....have had better luck with the latest one though.
RobbyGT is offline
Closed Thread Digital Recorders (PVRs) General
