comast dvr problems for the new guy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2005, 01:31 AM - Thread Starter
ninemode's Avatar
just had installed comcast on demand hooked up to a older rca with only 1 digital inputs,(red white Yellow) i believe another red and white input for a vcr. it does have an s-video cable that goes from box to tv, there are 2 rca's plugged into the back of the new unit,(i imaginge for audio), i still want to hook up my nintendo gamecube and my dvd, player,do i need some adapter to allow 2 more components or can the back of the dvr box be used any info would be grear
ninemode is offline
post #2 of 3 Old 02-22-2005, 12:56 PM
reddavid's Avatar
Ninemode,
I'll try to answer your question. The 'red, white, yellow' inputs on your tv are 'composite' inputs (not digital, i think). the red/white is usually for the audio portion - maybe an audio output signal. anyway, these give you the lowest signal quality. The S-video input you mention will give you better picture quality.
You cannot use the comcast DVR to add other inputs (gamecube, vcr, etc.) to your TV.
You can buy an audio/video switch box to do this. they are available for composite, svideo, component, etc. inputs. I did this with an S-video switcher from Sony - only about $40. it has room for 4 different sources - cable, vcr, xbox, gamecube, etc - for both the audio and video portion of the signal. It 'automatically' senses the active signal and outputs this to the single output - to TV. worked nicely.
i just swapped this out to a component video switcher. this uses the 'red, green, blue' video inputs - which gives an even better signal than svideo.
hope this makes sense. i would recommend looking for an svideo switcher - if all your sources can output s-video.
red
reddavid is offline
post #3 of 3 Old 03-05-2005, 12:34 PM
jumpdiggity's Avatar
Thanks for that clear-cut reply from another newbie!
janeen
jumpdiggity is offline
Closed Thread Digital Recorders (PVRs) General
