Sa 8300 Hd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-10-2005, 04:26 PM - Thread Starter
BillJr106's Avatar
I am looking to add an additional hard drive to this device, as it only holds a modest 30 hours or so of HD content. Has anyone succesfully used the SATA connection on the back, and is there a site listing compatible drives? Also, will I need a standard SATA external kit to house the drive? Thanks. You can also email responses to BSHERIDAN@sighealth.com
BillJr106 is offline
post #2 of 6 Old 03-10-2005, 09:35 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally posted by BillJr106
I am looking to add an additional hard drive to this device, as it only holds a modest 30 hours or so of HD content. Has anyone succesfully used the SATA connection on the back, and is there a site listing compatible drives? Also, will I need a standard SATA external kit to house the drive? [/email]
If your 8300HD is running Passport software then you cannot get an external drive to work. In the future the cable companies will rent you a compatible SATA device to expand your storage.
But if you're running SARA software there's a guy who posted to the HDTV Recorders & Players forum about a week ago that he was able to connect an external drive and that it worked, and he gave details.
This is actually the wrong forum for HD DVR topics, it's pretty much all SD here.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 03-11-2005, 10:01 AM
dt_dc's Avatar
Here's the thread:
http://www.avsforum.com/avs-vb/showt...hreadid=516559
Pretty cool ...
dt_dc is offline
post #4 of 6 Old 05-16-2005, 03:58 PM
avmad's Avatar
How can I tell what software my 8300HD is running?
Thx
avmad is offline
post #5 of 6 Old 05-16-2005, 11:47 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
The easiest quickest way is to go into the Output Formats menu and see how they list the choices. If it lists 480i, 480p, 720p, and 1080i then it has Passport. SARA lists the choices differently and i can't remember what they say.
Another way is to turn it off, then unplug it for a few minutes and plug it in and watch the TV screen as it boots up. If it says Pioneer Passport on the splash screen then there ya go. I don't know what SARA does as it boots up.
There are specific threads in the HDTV Recorders forum with various combinations of cable company and software type so they may help you narrow it down.
Randy
post #6 of 6 Old 05-17-2005, 11:15 AM
avmad's Avatar
Hmm - So I have the Passport software. Damn! :(
avmad is offline
Closed Thread Digital Recorders (PVRs) General
