DVI Cable <===> SA_8000HD - AVS Forum | Home Theater Discussions And Reviews
Old 03-22-2005, 08:58 PM - Thread Starter
phusnikn's Avatar
I just got my first DVR from Timewarner which is a Scientfic America 8000HD box the cable guy hooked it up with Component Cables and I would like to use DVI cable to my TV which is a Samsung P5063W but i'm not sure which DVI Cable will be compatbile with these two devices can anyone recommened something ?
phusnikn is offline
Old 03-23-2005, 01:12 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
First off find out if the DVI connection on your SA8000 is even active - chances are it's not enabled as it seems only a few selected areas of the country have it working.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
