Motorola 6412 Forward Jump - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-20-2005, 06:42 PM - Thread Starter
p99rice's Avatar
Can someone identify the code and how to enter into remote for jumping ahead in 30 second jumps?
p99rice is offline
post #2 of 5 Old 04-20-2005, 08:57 PM
pstahl's Avatar
Here's the thread where I got the info. www*avsforum*com/avs-vb/showthread.php?postid=4565223 you'll have to put periods where the * are. I don't have enough reply's posted yet so I can't use the real url.
Pete
pstahl is offline
post #3 of 5 Old 04-20-2005, 09:04 PM
pstahl's Avatar
This is also a good place for remote codes www*hifi-remote*com/cgi-bin2/ueic.cgi?cbl_0476 (remove the * and replace with periods).
Pete
pstahl is offline
post #4 of 5 Old 04-21-2005, 07:31 AM
maggiefan's Avatar
Q: How do I program the 30 second skip?
A:
1. Press the "Cable" button at the top of the remote.
2. Press and hold the "Setup" button until the "Cable" button blinks twice.
3. Type in the code 994. The "Cable" button again blinks twice.
4. Hit (Do Not Hold) the "Setup" button
5. Enter in 00173 (for 30 second Skip)
6. Press whatever button you want “30 Second Skip� to be.
__________________
Larry
maggiefan is offline
post #5 of 5 Old 04-28-2005, 02:42 PM
Colesy's Avatar
Is it possible to program the remote for more than 30 second skips similar to the Tivo skip to hash?
Colesy
Colesy is offline
Closed Thread Digital Recorders (PVRs) General
