video capture from TiVo - AVS Forum | Home Theater Discussions And Reviews
Old 05-24-2005, 12:00 AM - Thread Starter
bscot68's Avatar
I have had the DTV Tivo DVR for a bit over a year and am very happy with its general performance. However there is some time when I would like to be able to record some shows to dvd or cdv. The market is saturated with video capture devices so I would like a little advice on the best way to connect to my pc and edit/burn to disc. I hear many differing stories on quality so I would appreciate a little input.
Help!
bscot68 is offline
Old 05-26-2005, 02:08 PM
td0804's Avatar
my configuration is DVR to DVD Recorder, rather than PC, although I'm sure it's about the same configuraiton - the key thing on the TIVO is to "Record to VCR" then on the receiving device, make sure it's the highest quality settings. I've been pretty satisfied with with quality of the recording - the size fore a 1hr file is about 7 gb.
td0804 is offline
