Optical Out on a RCA DirectTV DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-08-2005, 01:53 PM - Thread Starter
jaycook's Avatar
I just purchased a Toslink to Toslink Digital Optical Cable to run from my RCA DirectTV DVR to my Receiver. Come to find out that the toslink doesn't fit in the DVR. Does anyone know what I need (an adapter?) or a Optical Cable with a non-Toslink end??? The manual sure doesn't help! :rolleyes:
It sure looks like the slot is big enough for a Toslink end..but it won't fit and I have tried looking inside the slot...dunno :confused:
Any help appreciated....
Thanks ;)
jaycook is offline
post #2 of 5 Old 06-08-2005, 07:08 PM
tokerblue's Avatar
Quoted: 151 Post(s)
Liked: 97
There are only two types of digital connections on a STB and receiver. It is either a coaxial or toslink cable. If you're sure that your DVR has a toslink output, make sure you're inserting the toslink cable in correctly. It's not a perfect square as two of the corners slope in a little. Make sure that everything is lining up.
Can you list your exact model number of your DVR?
tokerblue is offline
post #3 of 5 Old 06-09-2005, 12:35 AM
Steve Mehs's Avatar
The model of the DVR doesn't matter, a DirecTiVo is a DirecTiVo. I have my TiVo hooked up via tolink and it fits fine.
Time Warner Cable – Signature Home Premium View w/Epix, Sports Pass, HD Pass, Spanish Tier, Cisco Explorer 8642HDC, Cisco Explorer 8742HDC Both Running ODN 7.3.0_29
DirecTV – Premier, HD Extra Pack, NFL ST Max, NHL CI, MLB EI, Whole House DVR, HR34-700 Running 0972, HR24-200 Running 0802
Steve Mehs is offline
post #4 of 5 Old 06-09-2005, 05:32 AM
CodeEcks's Avatar
I second the 2 opinions above...like tokerblue said just make sure you are lining up the wire correctly because it only fits in one way. its not a perfect square. good luck.
CodeEcks is offline
post #5 of 5 Old 06-22-2005, 10:40 AM
Macfan424's Avatar
Toslink cable comes with a tiny plastic protector on the end. The first time I tried to install one, I didn't know this and tried to make it fit with the cap still on. Needless to say, it didn't fit. Finally emailed the vendor, who guessed right away what my problem was. :o
He very kindly said other customers had made the same mistake.
Macfan424 is offline
Closed Thread Digital Recorders (PVRs) General
