How do I connect a DVD recorder to my dual tuner Comcast(6412) DVR - AVS Forum | Home Theater Discussions And Reviews
Old 06-11-2005, 07:04 PM - Thread Starter
schutter5's Avatar
:( I have a Sony HDef TV that is connected to a Motorola Dual Tuner DVR from Comcast. Is there any way to hook up a DVD recorder to transfer some of the shows i've recorded onto my DVR hard disk? Is there a way to hook up a DVD recorder and record directly unto it or it's hard disk? My cable is connected in to the dvr and out to the TV with component hookup. My sound is routed through a digital optical to a pioneer receiver. The TV speakers are set to off. Anyone have any suggestions for hooking up a dvd recorder???
Dennis Schutter
schutter5 is offline
Old 06-11-2005, 08:39 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 511 Post(s)
Liked: 771
The Motorola's Video Input jacks are inactive everywhere in the country as far as i know. No way to transfer video onto your DVR from any outside source. It will only record from the two internal tuners.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 06-13-2005, 04:26 PM
dons459's Avatar
Yes you can record from your dvr box using composit or s-video and analog audio out from the dvr box to your dvd recorder. You wont be able to use the box for changing channels while its sending the signal out to your dvd recorder so you will need to use maybe ant a or b if you have cable or antenna connected to your tv if you want to watch tv at the same time.
dons459 is offline
Old 06-13-2005, 08:56 PM
"Don't PM Me Bro"
Quoted: 511 Post(s)
Liked: 771
The way you worded this it looked to me like you wanted to record something from your DVD recorder to your DVR's hard drive but now that i read it again it looks more like you want to transfer stuff trapped on your DVR to a DVD recorder. So yeah, you can do that :D
Randy
