Record DVD or VHS onto DVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-01-2005, 08:16 PM - Thread Starter
clouddancer79's Avatar
Hi... I just got a DCT6412 from Comcast. I'd really like to know if I can record a DVD onto the DVR for future viewing without the DVD? Same goes for VHS. If there is a way, could I have basic step-by-step instructions? Any help would be much appreciated!
clouddancer79 is offline
post #2 of 8 Old 07-02-2005, 12:54 AM
Joxer's Avatar
Nope you can't do it.
Joxer is offline
post #3 of 8 Old 07-02-2005, 02:05 AM - Thread Starter
Ok, thanks. Thats a bummer though... would be nice to have a collection of DVD's on your DVR hard drive. Oh well... thanks again.
post #4 of 8 Old 07-02-2005, 09:46 AM
Axatax's Avatar
Sure you can.
Axatax is offline
post #5 of 8 Old 07-02-2005, 12:06 PM - Thread Starter
If you know how, could you tell me?
post #6 of 8 Old 07-04-2005, 12:54 PM
sher's Avatar
Originally Posted by Axatax
Sure you can.
if you have comcast motorolla 6412 recorder, can you somehow retrieve the recorded programing and them burn it to a dvd?
there's a usb port . . . .
also, i've been shopping for a new laptop and am considering a g4 mac, mostly because it has the ability to record, burn, and play hd.
i''m a neophyte with all of this . . .
anyone out there who has figured out how to use the comcast dvr to facilitate burning dvd?
or do you know a way to hook into a receiver to achieve the access?
thanks
sherry
sher is offline
post #7 of 8 Old 07-04-2005, 02:01 PM
Joxer's Avatar
The USB port isn't used on the box - its planned for adding inputs like a keyboard, not a video output. The way to record a program from the DVR is to play the program and use the analog composite or s-video 480i output and use a video capture board/device on the computer to capture downconverted 480i video and stereo analog audio with software that encodes it to DVD-compatable 720x480 MPEG2 format and then use DVD authoring software to prepare the files for burning for a DVD-video.
However the starter of this thread doesn't want to record a program from the DVR to an external device - he wants to go the other way, record a program on the DVR from a DVD or VCR as the source.
Joxer is offline
post #8 of 8 Old 07-16-2005, 09:06 AM
cprompt's Avatar
Joxer:
I am coming to you as an expert. How can I achieve superior sound using a DVD recorder. A DVD recorder only has the red & white inputs, and a stereo VCR only has the red & white as well. My question is could I route these two wires thru a stereo or home theater system and achieve better sound quality? Please elaborate as much as possible. Thank You.
cprompt is offline
Closed Thread Digital Recorders (PVRs) General
