Is Time Warner (NYC/Queens) using the Multi Room 8300 yet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-11-2005, 05:45 AM - Thread Starter
BirdOPrey5's Avatar
I see on the SA site that it should be available, the Time Warner site doesn't mention multi-room ability one way or the other, which leads me to believe it's not yet available... I could call them but I doubt I would speak to anyone who knows what they are talking about.
I've had an Explorer 8000 for over a year and it works great. I just bought a house and have been running the RG6 cable while I have my walls and basement ceiling all open... I'm wondering if I should run a 2nd line of RG6 cable to each room to "broadcast" the exisitng Explorer 8000 or 8300 signal to my other TV's or if the Multi-room box is out (or will be any day now).
BirdOPrey5 is offline
post #2 of 4 Old 07-16-2005, 08:03 PM
DJ_V's Avatar
You won't need a 2nd line of cable for the multi-room to work. You will need all the cable lines in your house to converge to a point where they can connect to the main cable feed from outside. For the multi-room they have a special 4-way splitter that is required. So you'll have the cable feed coming into the splitter, and split out to up to 4 cable boxes in your house. You can have the multi-room 8300 "server" on any one of those 4, and up to 3 "client" cable boxes connected to the rest.
Hope that makes sense.
I've had the 8300HD multi-room for about 6 months now. It works great.
DJ_V is offline
post #3 of 4 Old 12-07-2005, 06:48 PM
dk0r's Avatar
Through Time-Warner? If so.. Where are you located?
I'm in upstate New York, and just called time warner regarding the 8300 hd multiroom.
The rep stated the latest model available was the 8300HD...
No Multi-Room :(
Question tho!
If I buy the 8300HD Multi-room retail, would I be able to utilize the multi room feature?
Or might Time-Warner have some anti 8300HD multi-room firmware in the non multiroom SA-8000 boxe's I would be 'streaming' too?
dk0r is offline
post #4 of 4 Old 12-08-2005, 07:18 AM
dt_dc's Avatar
No (for many reasons).
dt_dc is offline
Closed Thread Digital Recorders (PVRs) General
