Motorola 6412 Harddrive Upgrade ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-15-2005, 05:47 PM - Thread Starter
montano's Avatar
Has anyone tried ghosting a larger hard drive for use in a 6412 ?
montano is offline
post #2 of 14 Old 11-15-2005, 11:12 AM
editdogg's Avatar
I second that. What is the OS and what type drive would I need. size/RPM etc.
thanks!
editdogg is offline
post #3 of 14 Old 11-15-2005, 12:45 PM
Bud-man's Avatar
What ive read is only linux can read the drive and contents, and theres a 136 gig barrier to overcome....forget it boy's!!
Bud-man is offline
post #4 of 14 Old 12-15-2005, 10:08 PM
JGCREWS's Avatar
To the best of my knowledge, it hasn't been successfully done. For lots of details on why, check this thread:
*************** (dot) com/htsthreads/
showflat.php/Cat/0/Number/687066/
an/0/page/0
JGCREWS is offline
post #5 of 14 Old 12-16-2005, 11:57 AM
11001011's Avatar
Not to mention you must remember that you do not own these units
Modifying them in any way could possibly fall under the same laws that govern hacking cable boxes.
A 'phile and his money are soon parted...
11001011 is offline
post #6 of 14 Old 06-10-2006, 06:22 PM
James99's Avatar
I do own my unit and I have successfully installed a larger HDD.
James99 is offline
post #7 of 14 Old 06-11-2006, 02:57 AM
bicker1's Avatar
It's only in the United States that cable companies aren't activating customer-owned 6412s.
bicker1 is offline
post #8 of 14 Old 06-15-2006, 07:03 PM
Bud-man's Avatar
Well james be more open and tell us how and what you did/use, pm me if you feel free.
120 gigs is hardly enough to use i have plenty of hard drives from 160-300 gig.
Bud-man is offline
post #9 of 14 Old 06-16-2006, 10:30 AM
Andrew Wolfe's Avatar
That would be surprising since Motorola sells a 160GB version.
Andrew Wolfe is offline
post #10 of 14 Old 06-16-2006, 01:23 PM
Bud-man's Avatar
The 160 gig version isnt a 6412 it's a 6416 with newer firmware, i'm sure theres still a Barrier, isn't like you can slap a 300 gig drive in there and it's gunna recognize the size.
Bud-man is offline
post #11 of 14 Old 06-16-2006, 04:43 PM
You can do that with every other unit that has upgradable drives. (i.e. Tivo/Replay) and the Sony uses 250GB drives. I don't think this is an issue at all. I think that the software just has some security mechanism in it to prevent any drive swap at all. A copy of the original partitions may be enough to get around that.
post #12 of 14 Old 06-21-2006, 12:22 AM
golferadam's Avatar
It has been reported that the 120GB drive in the DCT6412 can be swapped for a 160GB drive, but the firmware prevents recognition of anything higher than 160GB:
http://www.avsforum.com/avs-vb/showt...&&#post7782273
golferadam is offline
post #13 of 14 Old 06-26-2006, 04:16 PM
chriskep1's Avatar
I rented a 6412 from Comcast to record programming and then take the box in my motorhome to watch programming in areas of no reception. I think Comcast in their wisdom has defeated me. If the service cable is disconnected it will still work on recorded shows until the first time it is powered down then, unless the box is connected to the service cable I get the "service momentarily" message even if I just try to access the contents of the hard drive. Does anyone know of a way around this? Comcast says there is no way. I'm dissapointed. I only got the box for that reason. Thanks in advance for any help.
chriskep1 is offline
post #14 of 14 Old 06-27-2006, 03:26 AM
bicker1's Avatar
This was just discussed in another thread. Presumably, when the box powers on, it needs to determine whether you're authorized or not. Since it cannot get its feed, it cannot validate you, and therefore waits until it can.
bicker1 is offline
Closed Thread Digital Recorders (PVRs) General
