8300 remote options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-27-2005, 12:39 PM - Thread Starter
johnner1999's Avatar
Quoted: 13 Post(s)
Can you set up the factory remote to control the volume of an audio receiver?
I know it can control the TV volume but I want to use the Dolby Digital sound from my Panasonic SA-XR50 amp. With out using a couple of remotes :-)
John
johnner1999 is offline
post #2 of 3 Old 08-27-2005, 02:07 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 510 Post(s)
Liked: 771
The 8300/8300HD series came with several different types of remote across the country so it may hinge on exactly which remote you have. Some people have said they were able to control their A/V receiver volume with theirs so maybe only some will do it or maybe all of em. Does your remote have an Audio mode/button? Do your instructions say anything about using it to control an A/V system?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 3 Old 08-29-2005, 09:09 AM - Thread Starter
Quoted: 13 Post(s)
nope mine has just "standard" controls; besides the Harmony what remote works very well with these STB's? I would want an easy to use A/B/C buttons and "list" type button :-)
Closed Thread Digital Recorders (PVRs) General
