SA 8000HD - Output to SDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-28-2005, 04:55 AM - Thread Starter
mflanagan's Avatar
I just got a SA 8000HD box and it works great with my HDTV downstairs. My problem is that for the life of me I cant get it to output Standard def to my TV upstairs. The onlyout put I could use is the ' Archive to VCR' or the Coaxial out.
I'm trying not to have to rent another cable box for my Standard Def TV's if I can. Is there any way to get this thing to output standard def?
Thanks!!
Flan's Theater!
Xbox Gamertag: Darth Flan
mflanagan is offline
post #2 of 5 Old 08-28-2005, 10:23 AM
miklk's Avatar
What's wrong with the coax to share?
I have the same HD box downstairs and I use the coax to go upsatirs (remote extenders to control box) and i get a very good picture that way?
miklk is offline
post #3 of 5 Old 08-28-2005, 02:27 PM - Thread Starter
mflanagan's Avatar
Does the Coax output Standard def to your other TV's? All I get is a black picture from that output.
Flan's Theater!
post #4 of 5 Old 08-28-2005, 10:40 PM
Joxer's Avatar
The SA8000HD doesn't support simultaneous HD and SD outputs. However the newer model SA8300HD does. Ask your cable company to swap for the newer model - it can output simultaneously a downconverted RF output on channel 3 at the same time as a HD output on the component or DVI output.
Joxer is offline
post #5 of 5 Old 08-29-2005, 04:28 AM - Thread Starter
mflanagan's Avatar
Beautiful! Thanks Joxer I will do that today. I've been pulling my hair out with this 8000 Box!
Flan's Theater!
Closed Thread Digital Recorders (PVRs) General
