How do I hook up a dvd recorder to the Motorola 6412? - AVS Forum | Home Theater Discussions And Reviews
Old 09-21-2005, 05:48 PM - Thread Starter
xsiveone's Avatar
I just purchased a Lite-on dvd recorder because I wanted to permanently save programs recorded to my dvr (Motorola 6412). How are people setting up a dvd recorder with this dvr?
xsiveone is offline
Old 09-22-2005, 07:20 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 505 Post(s)
Liked: 769
If you're not using the S-Video output (or Composite Video output) then you should be able to output a 480i signal to the S-Video input on your DVD recorder. I think the 6412 only has one set of Audio Output jacks so you'll probably have to split these to run to your TV and DVD player.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 09-23-2005, 12:03 PM - Thread Starter
xsiveone's Avatar
Thanks for the reply! It has a rca video out as well as an S-video, so video isn't the problem. It's the audio since the 6412 only has one audio out.
Can I split the audio output using a y-splitter? Is there any other solution to splitting the audio? This will probably hurt sound quality as well. I guess I could remove the y-splitter for when I'm not recording shows. I only want to save recorded shows stored on my dvr. I have no interest in recording shows live from the 6412 to the dvd recorder.
I wonder if I could temporarily hook up the audio out on the 6412 to the dvd recorder instead of having audio out hooked up to the tv. I wouldn't get any sound from the tv from the dvr while recording, but I should be getting sound to the dvd recorder from the dvr to record the shows.
Thanks again!
Chris
xsiveone is offline
Old 09-25-2005, 07:44 PM - Thread Starter
xsiveone's Avatar
Update: I got it worked out. Since the 6412 has more than one video out, but only has only one set of audio out, I bought a set of decent quality monster audio rca 1m 2f y-splitters, so I could split the sound from my tv and the dvd recorder.
I originally unhooked the audio from the tv and hooked it up to the audio on the dvd recorder, but I had to have the dvd recorder turned on and watch tv through the dvd recorder's tuner in order to get sound.
Thanks again for you help.
xsiveone is offline
Old 11-04-2005, 01:27 PM
chelentano's Avatar
how is the picture quality via s-video? is it worse then original DVR recording?
chelentano is offline
